Hi!
I'm currently using PCAN Explorer 5.3.5.852 for testing with units which also requires logging of data every second. I'm running 2 PCAN Explorers at the same time, one is for saving trace messages and the other is for communicating with the unit by macro. When I was debugging for 2 hrs only, everything is working as expected. But when I tried to run it for 8-9hrs, PCAN explorers stopped responding occasionally. It's frustrating to see that after 8hrs of testing, the programs just stopped. No other programs/software running aside from these 2. I would like to know what could be the possible reason and how to manage this issue. Thanks for any help.
PCAN Explorer 5 stops responding
Re: PCAN Explorer 5 stops responding
how much messages do you log in that time? Maybe your system ran out of memory, when you have a higher busload and you use dynamic buffering. That is why it will be better to use the LosslessTrace macro, which is included in each PCAN-Explorer setup, to log the data defined message packages directly on disk. Than you won´t run out of memory, when you want to log over a longer time.
BTW: there is a newer version of PCAN-Explorer available, see the news on the startpage of PCAN-Explorer for more details.
Hello Michael,
Yes, I'm using the Lossless Trace macro but the problem still occurs from time to time. By the way, I attached here a screenshot of an error I'm frequently encountering. What could be the possible reason and how to resolve this? Unfortunately, I cannot update to the latest version. It would require more effort to debug and test the whole project again, deployment is asap. Thanks for any help.
- Capture.JPG (21.42 KiB) Viewed 9492 times
Please update first to the latest Version (V5.4.) - see Start Window of your Software.
You use the Release from March 201. If you still have this problem, please post the error code again, or contact us directly at support@peak-system.com
Tried updating to the latest version but still I encountered the error below. I just execute a sub function for time checking, and this error always pops up when I exit the explorer. The version I used was ver.5.4.0.877. Any solution?
- Capture2.JPG (14.95 KiB) Viewed 9473 times
- Capture.JPG (23.82 KiB) Viewed 9473 times
to help you with your problem, please send your project by email to our support email address. We must reproduce the issue here on our systems, to find the cause of this error.
