start with PCAN-USB FD on Raspberry Pi 3, but get error
stahlstngel
Post by stahlstngel » Fri 29. Apr 2016, 09:58
i hope the category accords.
I setup the PCAN-USB FD on my Rpi3 and successfully compiled the netdev driver. I have no ECU to communicate now.....so i just terminated the CAN-Bus as you can see in the attachment (60 OHM and no Bus cable) for testing the adapter.
But:
I when i plug it in (LED: green), type "sudo ifconfig can0 up" and enter (LED: green blinking) and then write to the CAN-Bus "./cangen" or "./cansend" i get the error below (LED fast red blinking).
What do i also need to make the run the first simple tests?
------------------------------------------ERROR-------------------------------------------------
*------------- Beta____20160324_n (8.0.20) Apr 21 2016 20:02:42 --------------
*---------------------------- [mod] [usb] [net] -----------------------------
*--------------------- 1 interfaces @ major 243 found -----------------------
*n -type-  -ndev--base- irq  --btr-    --read--    --write-   --irqs--   -errors-      status
32  usbfd   can0        0 000 0x001c 0001a4d2 00000020 00000010 00000002 0x000c
Then i updated the adapter to firmware 2.2.1 as mentioned in a other topic.
Since this.....the adapter blinks red also after a "sudo ifconfig can0 down"+"sudo ifconfig can0 up".
Before i could fix the red blinking with this 2 commands. But now i have plug-out and plug in again.
How do i "reset" the adapter, because plug-out and plug-in is no option?
SYSTEM:
RPi3
$ uname -a
Linux RPi 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
$ cat /proc/net/can/version
rev 20120528 abi 9
CAN-Termination
CAN-Termination
Re: start with PCAN-USB FD on Raspberry Pi 3, but get error
Post by M.Maidhof » Fri 29. Apr 2016, 11:48
to have a working CAN system, you need at least two active CAN nodes, otherwise a communication is not possible, due to the missing acknowledge bit on the CAN frame.
It will be better to use our Linux category for such RPI/Linux questions.
stahlstngel
Post by stahlstngel » Fri 29. Apr 2016, 12:36
Okay, i wanna check this.
Thanks for now.
O.Hartkopp
Post by O.Hartkopp » Sun 8. May 2016, 18:57
When you want to use the SocketCAN tools like cansend and candump ... why did you use the separate PEAK-Linux driver then??
Since Linux 4.0 the PCAN USB FD adapters are supported by Mainline Linux. So your Linux 4.1 Kernel should run with the SocketCAN tools out-of-the-box when attaching the CAN USB FD adapter, see:
http://www.peak-system.com/forum/viewto ... 177&t=1296
Using the separate PEAK Linux driver only makes sense when you want to use the chardev programming API from (potentially existing?) chardev programs.
Oliver
O.Hartkopp
Post by O.Hartkopp » Sun 8. May 2016, 20:19
Besides the fact that you need to have a second CAN node which acknowledges your sent CAN frames (as Michael already noted) you can use the
restart-ms 200
option when you use the SocketCAN configuration tool 'ip'.
When an adapter goes into BUS-OFF it gets restarted after e.g. 200ms.
See chapter 6.5 here https://www.kernel.org/doc/Documentatio ... ng/can.txt
Oliver
stahlstngel
Post by stahlstngel » Tue 10. May 2016, 11:31
Thanks for your tips. Indeed with a second ECU it worked without errors.
The other problem was that the kernel option for the netdev was not set. That was the reason why i used the separate PEAK-Linux driver to activate the kernel option.
Thanks for your help.
stahlstngel
Post by stahlstngel » Tue 10. May 2016, 11:35
But how do i close this topic?
-- Thread closed ---
