Timestamp of received CAN msg
gmlim
Post by gmlim » Tue 17. May 2016, 00:44
Hi
I would like to understand for the below TPCANRdMsg structure what is the meaning for remainder in micro-seconds?
typedef struct {
	TPCANMsg Msg;          // the above message
	DWORD    dwTime;       // a timestamp in msec, read only
	WORD     wUsec;        // remainder in micro-seconds
} TPCANRdMsg;            // for PCAN_READ_MSG
I am currently using 2 Peak-CAN USB Pro FD devices on Linux Redhat with PeakCAN driver version 7.15.2 and chardev mode, for reading of CAN msg I am using blocking wait with timeout of 1 second.
May I check will the timestamp for the 2 seperate devices (e.g. device 1 and 2) be synchronised?
As I realised that when I unplug and reconnect one of the device (e.g. device 1), then I start to read in CAN msg from both devices, the timestamp of device 1 will show 0 for a period of time before it jumps to some values that is closer to the timestamp of device 2, but there is still quite a big difference in their received timestamps of around 500 ms.
Thank you for your time.
Re: Timestamp of received CAN msg
Post by PEAK-Support » Tue 17. May 2016, 11:17
Could you please download the latest BETA Driver Version 8.0.25 with CAN FD Support from our LINUX page and test this version. Therse are some timing features fixed.
gmlim
Post by gmlim » Wed 18. May 2016, 03:28
Hi Wilhelm
I have tried to install the latest BETA Driver Version 8.0.25 but it was not successful
Below are the output for your reference
[gm@gm peak-linux-driver-8.0.25-beta]$ make clean
make[1]: Entering directory `/usr/local/swdev/peak-linux-driver-8.0.25-beta/driver'
rm -f src/*o src/*~ src/.*cmd *o *ko *~ .*cmd  pcan.mod.c
make[1]: Leaving directory `/usr/local/swdev/peak-linux-driver-8.0.25-beta/driver'
make[1]: Entering directory `/usr/local/swdev/peak-linux-driver-8.0.25-beta/lib'
rm -f src/*~ src/*.o *~ *.so.* *.so
make[1]: Leaving directory `/usr/local/swdev/peak-linux-driver-8.0.25-beta/lib'
make[1]: Entering directory `/usr/local/swdev/peak-linux-driver-8.0.25-beta/test'
rm -f src/*~ src/*.o *~ receivetest transmitest bitratetest filtertest pcan-settings pcanfdtst
make[1]: Leaving directory `/usr/local/swdev/peak-linux-driver-8.0.25-beta/test'
make[1]: Nothing to be done for `depend'.
*** Host machine kernel version=2.6.32-431.el6.i686
*** Driver kernel version=2.6.32
*** Path to kernel sources=/lib/modules/2.6.32-431.el6.i686/build
*** use KBUILD=yes
*** cc version=4.4.7
make -C /lib/modules/2.6.32-431.el6.i686/build SUBDIRS=/usr/local/swdev/peak-linux-driver-8.0.25-beta/driver        EXTRA_CFLAGS="-I/usr/local/swdev/peak-linux-driver-8.0.25-beta/driver        -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNO_NETDEV_SUPPORT	 -DNO_RT " V=0 modules
make[2]: Entering directory `/usr/src/kernels/2.6.32-431.el6.i686'
  CC [M]  /usr/local/swdev/peak-linux-driver-8.0.25-beta/driver/src/pcan_main.o
In file included from /usr/local/swdev/peak-linux-driver-8.0.25-beta/driver/src/pcan_main.c:44:
/usr/local/swdev/peak-linux-driver-8.0.25-beta/driver/src/pcan_common.h:87:1: warning: "pr_warn" redefined
In file included from /usr/local/swdev/peak-linux-driver-8.0.25-beta/driver/src/pcan_common.h:51,
include/linux/kernel.h:586:1: warning: this is the location of the previous definition
/usr/local/swdev/peak-linux-driver-8.0.25-beta/driver/src/pcan_common.h: In function ‘pcan_getnow_ns’:
/usr/local/swdev/peak-linux-driver-8.0.25-beta/driver/src/pcan_common.h:118: error: implicit declaration of function ‘ktime_get_ns’
make[3]: *** [/usr/local/swdev/peak-linux-driver-8.0.25-beta/driver/src/pcan_main.o] Error 1
make[2]: *** [_module_/usr/local/swdev/peak-linux-driver-8.0.25-beta/driver] Error 2
make[2]: Leaving directory `/usr/src/kernels/2.6.32-431.el6.i686'
make[1]: *** [all] Error 2
cc src/libpcan.c -DNO_RT -I. -I../driver -fPIC -shared -O2 -Wall  -lc  -Wl,-soname,libpcan.so.0 -o libpcan.so.0.6
ln -sf libpcan.so.0.6 libpcan.so
cc src/libpcanfd.c -DNO_RT -I. -I../driver -fPIC -shared -O2 -Wall  -DPCANFD_OLD_STYLE_API -lc  -Wl,-soname,libpcanfd.so.0 -o libpcanfd.so.0.1
ln -sf libpcanfd.so.0.1 libpcanfd.so
cc -DNO_RT -g -I. -I../lib -I../driver  src/receivetest.c src/common.c  -lpcanfd -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o receivetest
cc -DNO_RT -g -I. -I../lib -I../driver  src/transmitest.cpp src/common.c src/parser.cpp  -lpcanfd -L../lib -L/lib -L/usr/lib -L/usr/local/lib -lstdc++ -o transmitest
cc -DNO_RT -g -I. -I../lib -I../driver  src/bitratetest.c src/common.c  -lpcanfd -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o bitratetest
cc -DNO_RT -g -I. -I../lib -I../driver  src/filtertest.cpp src/common.c  -lpcanfd -L../lib -L/lib -L/usr/lib -L/usr/local/lib -lstdc++ -o filtertest
cc -DNO_RT -g -I. -I../lib -I../driver  src/pcan-settings.c  -lpcanfd -L../lib -L/lib -L/usr/lib -L/usr/local/lib -lpopt -g -o pcan-settings
cc -DNO_RT -g -I. -I../lib -I../driver  src/pcanfdtst.c  -lpcanfd -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o pcanfdtst
[gm@gm peak-linux-driver-8.0.25-beta]$ sudo make install
Info: /lib/modules/2.6.32-431.el6.i686/misc exists.
cp: cannot stat `pcan.ko': No such file or directory
make[1]: *** [install_files] Error 1
mkdir -p /usr/lib
cp libpcan.so.0.6 /usr/lib
ln -sf libpcan.so.0.6 /usr/lib/libpcan.so.0
ln -sf libpcan.so.0 /usr/lib/libpcan.so
mkdir -p /usr/include
cp libpcan.h /usr/include
chmod 644 /usr/include/libpcan.h
cp libpcanfd.so.0.1 /usr/lib
ln -sf libpcanfd.so.0.1 /usr/lib/libpcanfd.so.0
ln -sf libpcanfd.so.0 /usr/lib/libpcanfd.so
cp libpcanfd.h /usr/include
chmod 644 /usr/include/libpcanfd.h
/sbin/ldconfig
cp receivetest transmitest bitratetest filtertest pcan-settings pcanfdtst /usr/local/bin
Thank you.
Post by PEAK-Support » Wed 18. May 2016, 09:02
Please use a Kernel Version 3.x - we do no longer support Kernel 2.x with our drivers. We only test all our new drivers on actually Kernel Version.
Saike
Post by Saike » Thu 2. Jun 2016, 03:48
I'm facing the same problem.
I have downloaded BETA Driver Version 8.0.25.
When i sudo make install, it shows "cannot stat `pcan.ko': No such file or directory" error
I'm using ubuntu 14.04 kernel version 3.13.0
Please help
Post by PEAK-Support » Thu 2. Jun 2016, 08:39
Which "same problem" ? the original thread was a time stamp problem, the solution was to use a new Linux Version.So what exact is your Problem? If it is NOT the problem from the first thread entry, please opne a new one and explain in detail what does not work. First take a look at this thread and follow the text step by step.
You also need to decide if you want to use CahrDev or SocketCAN mode.
