I have a problem when communicating with PCAN-USB adapter which is connected to
J1939 simulator. The device was set to use RP1210 in PCAN Nets utility and I can
view data from it using PcanView.
I am writing a Qt-based program. I successfuly loaded PCANRP32.dll and exported
API functions from this library. A call to RP1210_ReadVersion was succesful. But
when I call RP1210_ClientConnect it returns error 142.
What's wrong with my program?
The program text is below:
#include <QApplication>
#include <QtCore>
#include <windows.h>
#include <iostream>
#include "PCAN_RP1210.h"
typedef short (__stdcall *tfn_RP1210_ClientConnect) ( HWND, short, char *, long, long, short );
typedef short (__stdcall *tfn_RP1210_ClientDisconnect) ( short );
typedef short (__stdcall *tfn_RP1210_SendMessage) ( short, char*, short, short, short );
typedef short (__stdcall *tfn_RP1210_ReadMessage) ( short, char*, short, short );
typedef short (__stdcall *tfn_RP1210_SendCommand) ( short, short, char*, short );
typedef void (__stdcall *tfn_RP1210_ReadVersion) ( char*, char*, char*, char* );
typedef short (__stdcall *tfn_RP1210_GetErrorMsg) ( short, char* );
typedef short (__stdcall *tfn_RP1210_GetHardwareStatus) ( short, char*, short, short );
typedef struct
tfn_RP1210_ClientConnect RP1210_ClientConnect;
tfn_RP1210_ClientDisconnect RP1210_ClientDisconnect;
tfn_RP1210_SendMessage RP1210_SendMessage;
tfn_RP1210_ReadMessage RP1210_ReadMessage;
tfn_RP1210_SendCommand RP1210_SendCommand;
tfn_RP1210_ReadVersion RP1210_ReadVersion;
tfn_RP1210_GetErrorMsg RP1210_GetErrorMsg;
tfn_RP1210_GetHardwareStatus RP1210_GetHardwareStatus;
device_api_t;
device_api_t api;
QString getErrorDescription( short errorCode )
QString res;
char dscr[ 2048 ];
short code = api.RP1210_GetErrorMsg( errorCode, dscr );
if( code == NO_ERRORS )
res = QString( "%1 (%2)" ).arg( QString::fromLatin1( dscr ) ).arg( errorCode );
else
std::cout << "Error translation failed:" << code << std::endl;
return res;
int main( int argc, char *argv[] )
QLibrary l( "PCANRP32.dll" );
api.RP1210_ClientConnect = (tfn_RP1210_ClientConnect)l.resolve( "RP1210_ClientConnect" );
api.RP1210_ClientDisconnect = (tfn_RP1210_ClientDisconnect)l.resolve( "RP1210_ClientDisconnect" );
api.RP1210_SendMessage = (tfn_RP1210_SendMessage)l.resolve( "RP1210_SendMessage" );
api.RP1210_ReadMessage = (tfn_RP1210_ReadMessage)l.resolve( "RP1210_ReadMessage" );
api.RP1210_SendCommand = (tfn_RP1210_SendCommand)l.resolve( "RP1210_SendCommand" );
api.RP1210_ReadVersion = (tfn_RP1210_ReadVersion)l.resolve( "RP1210_ReadVersion" );
api.RP1210_GetErrorMsg = (tfn_RP1210_GetErrorMsg)l.resolve( "RP1210_GetErrorMsg" );
api.RP1210_GetHardwareStatus = (tfn_RP1210_GetHardwareStatus)l.resolve( "RP1210_GetHardwareStatus" );
if( !( api.RP1210_ClientConnect
&& api.RP1210_ClientDisconnect
&& api.RP1210_SendMessage
&& api.RP1210_ReadMessage
&& api.RP1210_SendCommand
&& api.RP1210_ReadVersion
&& api.RP1210_GetErrorMsg
&& api.RP1210_GetHardwareStatus )
std::cout << "Api not resolved" << std::endl;
return 1;
char dllMajor[50];
char dllMinor[50];
char apiMajor[50];
char apiMinor[50];
api.RP1210_ReadVersion( dllMajor, dllMinor, apiMajor, apiMinor );
std::cout << "DLL version: " << dllMajor << "." << dllMinor << std::endl;
std::cout << "API version: " << apiMajor << "." << apiMinor << std::endl;
short cid = api.RP1210_ClientConnect( 0, PCAN_USB, J1939_STRING, 0, 0, 0 );
if( cid < 128 )
std::cout << "Connect succesful!" << std::endl;
else
std::cout << "Connect error:" << qPrintable( getErrorDescription( cid ) ) << std::endl;
return 1;
return 0;
