RX Frame CAN_SetTimestampHandler() example
Universal CAN Converter
O.Hartkopp
Post by O.Hartkopp » Sun 5. Jun 2016, 20:24
I would like to receive and evaluate CAN frames together with their timestamps.
In the provided example code from PCAN Router and PCAN Router pro the include can.h introduces a struct CANRxMsg_t which contains a 32 bit timestamp.
But no example uses this struct CANRxMsg_t and all examples disable the timstamp handler callback:
CAN_SetTimestampHandler ( CAN_BUS1, NULL);
1. Do you have an example how to use a struct CANRxMsg_t with filled timestamp and enabled timstamp handler callback?
2. Is there any documentation that tell about the unit (ms / ns) which is counted in the 32 bit timstamp counter?
Oliver
P.Steil
Hardware Development
Re: RX Frame CAN_SetTimestampHandler() example
Post by P.Steil » Mon 6. Jun 2016, 15:44
Hi Oliver,
you can use the example 3_TIMER as a basis.
- init the timer like in the example
- use CANRxMsg_t for the RX Queues
- create a copy of CAN_UserRead() for the CANRxMsg_t type
- add a handler for the timestamps like this:
void  ISRGetTime ( CANRxMsg_t *msg)
   // read timer register
   msg->TimeStamp32 = SYSTIME_NOW;
Philipp Steil
Reason: Reformatted the code for better readability.
phone: +49-6151-8173-20
fax: +49-6151-8173-29
O.Hartkopp
Post by O.Hartkopp » Tue 7. Jun 2016, 16:51
Hi Philipp,
following your suggestion
P.Steil wrote:you can use the example 3_TIMER as a basis.
I created a CAN_UserReadTS() function:
// CAN_UserReadTS()
// read message with timestamp from CAN_BUSx
u32_t  CAN_UserReadTS ( CANHandle_t  hBus, CANRxMsg_t *pBuff)
	u32_t  ret;
	CANRxMsg_t  *pMsg;
	ret = 0;
	pMsg = CAN_RxQueueGetNext ( hBus);
	if ( pMsg != NULL)
		pBuff->Id   = pMsg->Id;
		pBuff->Len  = pMsg->Len;
		pBuff->Type = pMsg->Type;
		pBuff->Data32[0] = pMsg->Data32[0];
		pBuff->Data32[1] = pMsg->Data32[1];
		pBuff->TimeStamp32 = pMsg->TimeStamp32;
		CAN_RxQueueReadNext ( hBus);
		ret = 1;
	return ret;
And a timestamp handler in can_user.c
// CAN_ISRGetTime()
// set timestamp in ISR for message
void  CAN_ISRGetTime ( CANRxMsg_t *rxmsg)
	rxmsg->TimeStamp32 = SYSTIME_NOW;
and enabled
// timestamp incomming frames
CAN_SetTimestampHandler ( CAN_BUS1, CAN_ISRGetTime);
And now
CANRxMsg_t  RxMsg;
// process messages from CAN1
if ( CAN_UserReadTS ( CAN_BUS1, &RxMsg) != 0)
returns proper CAN frames with timestamps :)
Thanks for the hints!
Oliver
