Hi
I am trying to control the leds (for debugging and monitoring purposes).
I succeed to turn on and off the green LEDs as descriced in the example that comes with it. I can not control the color of these LEds to Red or orange and I can not control the other LEDs (The RED blinking LEDs during programming).
Can you refer me to a more elaborated example and/or documentation in this regards?
Controlling LEDS in Pcan Router Pro
Re: Controlling LEDS in Pcan Router Pro
Did you use the PPCAN-Editor and configure the module, or do you use the C-Compiler and build a own firmware - this importend information is missing...
Sorry. I thought it was obvious.
I use the C compiler, writing my own code.
please take a look into the hardware.h file:
you will also find the definitions for the LEDs
and the color
//! Set a LED to a specific color.
//! @param hLED handle of the LED, see LED-handles
//! @param color color to set, see HW_LED_RED ...
//! @return one error of HW_ERR_...
HWStatus_t HW_SetLED ( LEDHandle_t hLED, LEDColor_t color);
//! @name LED-handles
//! Handles to the LEDs. Not all LEDs are available on all targets.
#define HW_LED_STATUS 0 //!< status LED
#define HW_LED_CAN1 1 //!< LED CAN1
#define HW_LED_CAN2 2 //!< LED CAN2
#define HW_LED_CAN3 3 //!< LED CAN3
#define HW_LED_CAN4 4 //!< LED CAN4
#define HW_LED_CAN1b 5 //!< second LED CAN1
#define HW_LED_CAN2b 6 //!< second LED CAN2
#define HW_LED_CAN3b 7 //!< second LED CAN3
#define HW_LED_CAN4b 8 //!< second LED CAN4
//! @name LED-colors
//! Colors used for the LEDs
#define HW_LED_OFF 0 //!< LED switch OFF
#define HW_LED_RED 1 //!< LED switch red
#define HW_LED_GREEN 2 //!< LED switch green
#define HW_LED_ORANGE 3 //!< LED switch orange
Thanks!
I saw all that and tried to change color of main LEDs (HW_LED_CANx) and succeeded only to set it to green or off.
for the secondary leds (HW_LED_CANxb) I couldn't set it at all. Continously off no matter what color I set.
HW_SetLED ( HW_LED_CAN4b, HW_LED_RED); should work?
Hello there.
PCAN-Router Pro has -no- multicolor LEDs at CAN ports.
One is green and one is red.
You just may set them to either ON or OFF.
The file is written to fit all our hardware products,
like e.g. PCAN Router which indeed has 2 multicolor LEDs.
But not 4 as defined in the file.
Also you may find that the PCAN-Router has no beeper ...
Greetings
Stefan
Greetings
Stefan
