signal generator like CANalayzer
bbergner
Post by bbergner » Mon 7. Nov 2011, 12:30
I try to generate a position signal with the PCAN-Explorer. Therefore I use the signal generator in CANalyzer. Is there a function at the PCAN-Explorer like this?
Re: signal generator like CANalayzer
Post by M.Maidhof » Mon 7. Nov 2011, 16:36
you can use instruments panel objects to generate data, or you can also write a VB or standard macro file to generate a periodical signal (sinus etc).
best regards
