Seperate variables by CAN-ID and content of ByteX
Visualization and Recording of CAN Data
tcarlso
Post by tcarlso » Fri 9. Dec 2016, 15:07
The Minidisplay supports using Scenes the possibility of different CAN-IDs. This is working fine.
[variable1]
name="speed"
canid=0x100 // ID
position=0,8 // Bit start and length
In our System, the CAN-ID is not the only way to seperate values. Unfortunately we seperate the Content by using additionally Byte1 of the CAN-Message.
Example
canid=0x123, Byte1= 11, Variable1 is on Position 16,8
canid=0x123, Byte1= 12, Variable2 is on Position 24.16
Is there any possibility to seperate the variables not only using the CAN-ID?
At the Moment we always overwrite variable1 by variable2 if the next CAN-message is received.
G.Bohlen
Hardware Development
Re: Seperate variables by CAN-ID and content of ByteX
Post by G.Bohlen » Fri 9. Dec 2016, 16:38
it is possible to define "multiplexer" to interpret the databytes differently.
At least Firmware V1.1.5 is required.
Start with the definition of the multiplexer:
[variable1]
name="Var1_mux"
messagename="testmessage1"
position=0,8 // bitstart,bitlen
byteorder=0 // 0=intel, 1=Motorola
muxtype=1 // 0=none, 1=multiplexer, 2=multiplexed
muxval=0 // if muxtype=2, variable is updated in case current multiplexor has this value
scale=1 // scale set to 1
offset=0 //
vartype=0 // 0=unsigned, 1=signed, 2=float, 3=double(not supported)
datatype=0 // result is unsigned
timeoutval=0
Then define the "multiplexed" variables. Here two variables Var2a and Var2b are defined.
In case the multiplexer-value is "1" Var2a is updated.
In case the multiplexer-value is "2" var2b is updated.
[variable2]
name="Var2a"
position=32,16 // bitstart,bitlen
muxtype=2 // 0=none, 1=multiplexor, 2=multiplexed
muxval=1 // if muxtype=2, variable is updated in case current multiplexor has this value
offset=0 //
[variable3]
name="Var2b"
muxval=2 // if muxtype=2, variable is updated in case current multiplexor has this value
offset=0 //
Post by PEAK-Support » Fri 9. Dec 2016, 16:48
The latest Package incl. the Firmware could be download from here
