peak-linux-driver-8.2 chardev not working on 64 bit
andre_bauer
Post by andre_bauer » Tue 24. Jan 2017, 16:00
Hey,
I installed the peak-linux-driver-8.2 on Ubuntu. CAN connection is via PCI card. After a reboot reading from CAN works sometimes for a short time. The output of cat /proc/pcan looks like this, when its not working anymore
cat /proc/pcan
*------------- Release_20161108_n (8.2.0) Dec  2 2016 14:24:50 --------------
*--------------------- 2 interfaces @ major 244 found -----------------------
 0    pci   -NA- f9ce0000 016 0x011c 00000000 00000000 00000001 00000004 0x0002
 1    pci   -NA- f9ce0400 016 0x001c 00000000 00000000 00000000 00000001 0x0002
cat /dev/pcan0 receives no messages
EDIT:I almost forgot: Same hardware configuration works on Ubuntu 32bit flawlessly. That means the hardware part seems to be correct.
Hope you can help me and thanks!
Re: peak-linux-driver-8.2 chardev not working on 64 bit
Post by M.Maidhof » Thu 26. Jan 2017, 11:27
you are using different baudrates on the channels. Please tell us your hardware setup and baudrate of your external CAN node. Sure you use terminated CAN cable?
andre_bauer
Post by andre_bauer » Thu 26. Jan 2017, 12:30
Hey Michael,
only channel 0 is connected to a CAN bus channel 1 ist not plugged in. It is one PCI card with 2 CAN channels(ports) Termination should be fine since it works on 32bit flawlessly right? I will look at the baudrate on 32 bit and then check if it is the same. If not how can I configure the baudrate the driver/card hast to use?
Greetings
André
Post by M.Maidhof » Fri 27. Jan 2017, 09:07
to change the baudrate, you have to use the "echo" command, please see driver manual on page 23 for more details.
andre_bauer
Post by andre_bauer » Tue 31. Jan 2017, 11:16
Installing 8.3 drivers fixed the issues. Now everything works perfectly. Thanks for your work and keep it up :)
