FMS interface: Replacement for PCAN-GPRS?
robinguillaume
Post by robinguillaume » Mon 13. Mar 2017, 14:51
we are using PCAN-GPRS.
We use only fms interface and rs 232 interface (and not gprs and gps ).
Our C program collects fms data to send them on Rs-232 com either in real time either in time-deferred batch.
In this context have you a solution to replace PCAN-GPRS ?
Thanks.
Dominique
Re: FMS interface
Post by M.Maidhof » Mon 13. Mar 2017, 17:49
if you only need CAN and RS232, the PCAN-RS232 could be a suitable solution for you:
http://www.peak-system.com/PCAN-RS-232.287.0.html?&L=1
robinguillaume
Re: FMS interface
Post by robinguillaume » Wed 15. Mar 2017, 12:23
hi,
thanks for your answer.
i looked at http://www.peak-system.com/PCAN-RS-232.287.0.html?&L=1. Functionnaly, it seems not bad, but
the problem is the memory size, we have batch files which can reach 40ko.
have you something with more memory?
Regards.
Dominique.
Re: FMS interface
Post by M.Maidhof » Wed 15. Mar 2017, 15:46
unfortunately we don´t have a hardware with CAN and RS232 with more memory at the moment.
What kind of memory is needed? RAM or EEprom?
robinguillaume
Re: FMS interface
Post by robinguillaume » Wed 15. Mar 2017, 16:06
Any kind of memory eeprom or ram.
(The sd card of the PCCAN_GPRS was perfect, but it was formerly...)
Re: FMS interface
Post by PEAK-Support » Tue 21. Mar 2017, 11:54
Only the units we have in our shop - technical datasheet is always avaiable from the downloads tab.
