I am trying to spawn a powershell program from PCAN VBScript. I have it working in windows VBScript but cannot get it working using the engine in PCAN Explorer. The motivation here is to pop up a dialog to the person creating the trace file so that they can save it to a named network location in a particular format, via a marco, without any user interaction other than selecting some parameters from dropdowns and list boxes.
Perhaps there is a better way to do this. I intended to force run the macro on exit so that the user would have to save the file to the correct location in the correct format.
Here is the listing for the Powershell. Let's call it
Buttons.ps1
[void] [System.Reflection.Assembly]::LoadWithPartialName("System.Windows.Forms")
[void] [System.Reflection.Assembly]::LoadWithPartialName("System.Drawing")
$objForm = New-Object System.Windows.Forms.Form
$objForm.Text = "Select a Computer"
$objForm.Size = New-Object System.Drawing.Size(300,200)
$objForm.StartPosition = "CenterScreen"
$objForm.KeyPreview = $True
$objForm.Add_KeyDown({if ($_.KeyCode -eq "Enter")
{$global:x=$objListBox.SelectedItem;$objForm.Close()}})
$objForm.Add_KeyDown({if ($_.KeyCode -eq "Escape")
{$objForm.Close()}})
$OKButton = New-Object System.Windows.Forms.Button
$OKButton.Location = New-Object System.Drawing.Size(75,120)
$OKButton.Size = New-Object System.Drawing.Size(75,23)
$OKButton.Text = "OK"
$OKButton.Add_Click({$global:x=$objListBox.SelectedItem;$objForm.Close()})
$objForm.Controls.Add($OKButton)
$CancelButton = New-Object System.Windows.Forms.Button
$CancelButton.Location = New-Object System.Drawing.Size(150,120)
$CancelButton.Size = New-Object System.Drawing.Size(75,23)
$CancelButton.Text = "Cancel"
$CancelButton.Add_Click({$objForm.Close()})
$objForm.Controls.Add($CancelButton)
$objLabel = New-Object System.Windows.Forms.Label
$objLabel.Location = New-Object System.Drawing.Size(10,20)
$objLabel.Size = New-Object System.Drawing.Size(280,20)
$objLabel.Text = "Please select a computer:"
$objForm.Controls.Add($objLabel)
$objListBox = New-Object System.Windows.Forms.ListBox
$objListBox.Location = New-Object System.Drawing.Size(10,40)
$objListBox.Size = New-Object System.Drawing.Size(260,20)
$objListBox.Height = 180
[void] $objListBox.Items.Add("atl-dc-001")
[void] $objListBox.Items.Add("atl-dc-002")
[void] $objListBox.Items.Add("atl-dc-003")
[void] $objListBox.Items.Add("atl-dc-004")
[void] $objListBox.Items.Add("atl-dc-005")
[void] $objListBox.Items.Add("atl-dc-006")
[void] $objListBox.Items.Add("atl-dc-007")
$objForm.Controls.Add($objListBox)
$objForm.Topmost = $True
$objForm.Add_Shown({$objForm.Activate()})
[void] $objForm.ShowDialog()
Write-Host $x
Let's now invoke this Powershell from the DOS command line as a vbs. Let's call it
GetFile.vbs
engine = lcase(mid(WScript.FullName, InstrRev(Wscript.FullName, "\")+1))
if not engine = "cscript.exe" then
MsgBox "launch with cscript.exe"
Wscript.Quit
end if
pscommand = "K:\PcanTrace\Buttons.ps1"
cmd = "powershell.exe -noprofile -command " & pscommand
Set shell = CreateObject("WScript.Shell")
Set executor = shell.Exec(cmd)
executor.StdIn.Close
MsgBox executor.StdOut.ReadAll
Converting this to a macro for PCAN Explorer...
'FILE DESCRIPTION: Test and sample macros
Option Explicit
Sub TestPowershellExec()
'DESCRIPTION: Force save PCAN Trace file to network drive
Dim pscommand
Dim cmd
Dim Shell
Dim executor
Set Shell = CreateObject("Shell.Application")
Set executor = Shell.Exec(cmd)
End Sub
I have also tried it this way...
Option Explicit
Dim pscommand
Dim cmd
Dim Shell
Dim executor
Dim engine
'engine = lcase(mid(WScript.FullName, InstrRev(Wscript.FullName, "\")+1))
'MsgBox engine
Set Shell = CreateObject("WScript.Shell")
End Sub
Option Explicit
Dim pscommand
Dim cmd
Dim Shell
Dim executor
End Sub
Is it possible to do this? Any insights would be appreciated.
Liam
