building the current PCAN driver 8.3.1 for SUSE Linux Enterprise 11 SP4 kernel 3.0.101 fails when netdev mode is required.
be23723@test2:~/driver/pcan/peak-linux-driver-8.3.1> make NET=NETDEV_SUPPORT
make[1]: Entering directory `/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver'
make[1]: warning: jobserver unavailable: using -j1. Add `+' to parent make rule.
make[1]: Nothing to be done for `depend'.
make[1]: Leaving directory `/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver'
*** Host machine kernel version=3.0.101-rt130-65-rt
*** Driver kernel version=3.0.101
*** Path to kernel sources=/lib/modules/3.0.101-rt130-65-rt/build
*** use KBUILD=yes
*** cc version=4.3
make -C /lib/modules/3.0.101-rt130-65-rt/build SUBDIRS=/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver EXTRA_CFLAGS="-I/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT " V=0 modules
make[2]: Entering directory `/usr/src/linux-3.0.101-rt130-65-rt-obj/x86_64/rt'
make -C ../../../linux-3.0.101-rt130-65-rt O=/usr/src/linux-3.0.101-rt130-65-rt-obj/x86_64/rt/. modules
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_main.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_fops.o
In file included from /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_fops.c:550:
/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_fops_linux.c:1357:2: warning: #warning "Compiling for __LP64__"
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_fifo.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_filter.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_parse.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_sja1000.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_common.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_timing.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcanfd_core.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcanfd_ucan.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_pci.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcanfd_pci.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_pciec.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_isa.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_dongle.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_pccard_core.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_pccard.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_usb_core.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_usb.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_usbpro.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcanfd_usb.o
CC [M] /home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_netdev.o
/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_netdev.c: In function ‘pcan_netdev_rx’:
/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_netdev.c:398: error: ‘priv’ undeclared (first use in this function)
/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_netdev.c:398: error: (Each undeclared identifier is reported only once
/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_netdev.c:398: error: for each function it appears in.)
/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_netdev.c: In function ‘pcan_netdev_restart_work’:
/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_netdev.c:831: error: ‘struct can_priv’ has no member named ‘restart_work’
/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_netdev.c:831: warning: type defaults to ‘int’ in declaration of ‘__mptr’
/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_netdev.c:831: warning: initialization from incompatible pointer type
/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_netdev.c: In function ‘pcan_netdev_register’:
/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_netdev.c:958: error: ‘struct can_priv’ has no member named ‘restart_work’
make[5]: *** [/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver/src/pcan_netdev.o] Error 1
make[4]: *** [_module_/home/be23723/driver/pcan/peak-linux-driver-8.3.1/driver] Error 2
make[3]: *** [sub-make] Error 2
make[2]: *** [all] Error 2
make[2]: Leaving directory `/usr/src/linux-3.0.101-rt130-65-rt-obj/x86_64/rt'
make[1]: *** [all] Error 2
make[1]: Entering directory `/home/be23723/driver/pcan/peak-linux-driver-8.3.1/lib'
cc -o libpcan.so.0.6 -DNO_RT -I. -I../driver -fPIC -shared -Wall src/libpcan.c -Wl,-soname,libpcan.so.0
cc -o libpcanfd.so.0.1 -DNO_RT -I. -I../driver -fPIC -shared -Wall -DPCANFD_OLD_STYLE_API src/libpcanfd.c -Wl,-soname,libpcanfd.so.0
ln -sf libpcanfd.so.0.1 libpcanfd.so
make[1]: Leaving directory `/home/be23723/driver/pcan/peak-linux-driver-8.3.1/lib'
make[1]: Entering directory `/home/be23723/driver/pcan/peak-linux-driver-8.3.1/test'
cc -DNO_RT -g -I. -I../lib -I../driver src/receivetest.c src/common.c -lpcanfd -L../lib -o receivetest
cc -DNO_RT -g -I. -I../lib -I../driver src/transmitest.cpp src/common.c src/parser.cpp -lpcanfd -lstdc++ -L../lib -o transmitest
cc -DNO_RT -g -I. -I../lib -I../driver src/bitratetest.c src/common.c -lpcanfd -L../lib -o bitratetest
cc -DNO_RT -g -I. -I../lib -I../driver src/filtertest.cpp src/common.c -lpcanfd -lstdc++ -L../lib -o filtertest
cc -DNO_RT -g -I. -I../lib -I../driver src/pcan-settings.c -lpopt -L../lib -g -o pcan-settings
cc -DNO_RT -g -I. -I../lib -I../driver src/pcanfdtst.c -lpcanfd -L../lib -o pcanfdtst
make[1]: Leaving directory `/home/be23723/driver/pcan/peak-linux-driver-8.3.1/test'
Thanks.
F.Benad
