Delta V
PMJ
Delta V
Post by PMJ » Mon 9. Jan 2012, 12:57
I receive 72 voltages (V1,V2,.....,V72) in multiplex on ID 202h and i need calculated delta V. It is possible in PCAN explorer??
Piter
Re: Delta V
Post by M.Maidhof » Tue 10. Jan 2012, 11:51
yes, thats possible. You have to write a small VBmacro to calculate a third signal out of two given signals. Here is an example:
Sub CalculatePower()
Dim voltage, current, power
Set power = Signals("Power")
If power Is Nothing Then
End If
While True
Wend
End Sub
