Super Large /var/log files
thorpey01
Post by thorpey01 » Thu 31. Mar 2016, 13:02
I have been using the CharDev drivers and the PCAN Basic API to write Python code to send and receive CAN messages.
How do I turn off logging of CAN messages to /var/log/ kern.log and syslog etc
I am seeing massive log files being produced .. one is 50GB ! .. i look in the logs and they are full of all the CAN messages I am looking at.
can i just delete these massive log files with SUDO? How do i stop them logging again.. ?
best regards,
Nicholas
Re: Super Large /var/log files
Post by M.Maidhof » Thu 31. Mar 2016, 16:34
which driver version do you use and with which settings did you compile it? Please send the output of cat /proc/pcan to see more details
thorpey01
Post by thorpey01 » Thu 31. Mar 2016, 17:15
*------------- Release_20150729_n (7.15.2) Mar 9 2016 13:02:06 --------------
*--------------------- 2 interfaces @ major 246 found -----------------------
32 usbpfd -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
33 usbpfd -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
rdm@rdm-Inspiron-1501:/var/log$
thorpey01
Post by thorpey01 » Fri 1. Apr 2016, 16:38
I've done a bit of research on this .. it could be a bug with Ubuntu.. possible solutions are to turn off ACPI in the BIOS.. I can't beleive Ubuntu could just let these log files grow to such large files as 50 GB .. and fill up your hardrive so that your PC is inoperable..
S.Grosjean
Post by S.Grosjean » Tue 5. Apr 2016, 12:24
Could you please give us an extract of these logs (last 50 lines, for example), something like:
$ dmesg | tail -n 50
We'll see what are the reasons of these logs,
Thanks.
Stéphane
— Stéphane
monty_hall
Post by monty_hall » Wed 26. Apr 2017, 21:50
I'm having the exact same problem too. kernel and syslog chocked full of pcan transaction information.
S.Grosjean
Post by S.Grosjean » Thu 27. Apr 2017, 10:00
Could you please give us the output of:
$ cat /proc/pcan
as well as:
$ dmesg | grep pcan
Stéphane
— Stéphane
