I have an application with some data representing a 4 digit number that is transmitted in two separate CAN frames - 2 digits in one message, and 2 digits in another.
e.g.
FormatVersion=5.0 // Do not edit this line!
Title="Untitled"
{SENDRECEIVE}
[LAST_TWO]
ID=183h
Var=SECOND unsigned 56,4
Var=FIRST unsigned 60,4
[FIRST_TWO]
ID=182h
Var=FOURTH unsigned 24,4
Var=THIRD unsigned 28,4
I believe I can use a virtual variable to combine the 4 digits using a macro, but I am curious if it is possible to use a virtual variable within the symbol file itself to link this data? If not, is this a feature that could be added to the symbol file format? Or is there another way to show this data being linked across messages (without a macro)?
Basically what I'd like to do is be able to provide my end-user with symbol file only that provides this data, and not require that they run a macro as well.
I'm using P-CAN Explorer v5.4.1.898, Symbol Editor v3.2.1.364
