Monitor bus states with PPCAN-Editor
avisz
Post by avisz » Wed 24. May 2017, 14:09
In my system, I need to monitor the bus states. I saw a similar post in the forum but it looks like I can't implement the solution because it is not using PPCAN-Editor.
Is there a way to monitor the states with a specific configuration in PPCAN-Editor ?
Avi SZYCHTER
Re: Monitor bus states with PPCAN-Editor
Post by PEAK-Support » Thu 25. May 2017, 11:42
How do you want to monitor the BUS states? Writing on the CF card?
avisz
Post by avisz » Fri 26. May 2017, 09:25
First of all, i would like to change the state of a LED according to the bus state, but in the end I would like to change the behaviour of the router : for instance, I want to redirect my frames from CAN-1 to CAN-4 if everything is right, but I want to redirect my frames from CAN-1 to CAN-4 if CAN-4 is unavailable.
S.Schott
Hardware Development
Post by S.Schott » Mon 29. May 2017, 11:06
Hi there.
No, PCAN-Router Pro does not have indicators for that.
