High-speed USB 2.0 to CAN/LIN Interface
bm_kamath
Post
by bm_kamath » Thu 18. May 2017, 14:34
Hi Gunnar,
I have couple of questions:
- For some of my experiments , i wanted to destroy the "Single Bit" in the farme without inducing a 6 dominant bits. Is there any way to do that ?
- Also is there any way to selectively make the Bit dominant /recessive ?
bm_kamath
K.Wagner on Thu 18. May 2017, 15:12, edited 2 times in total.
Reason: Formatted in a list for better reading
G.Bohlen
- Hardware Development
Post
by G.Bohlen » Thu 18. May 2017, 15:49
it is not possible to modify only a single bit.
The module always generates a sequence of 6 dominant bits, starting at the defined bit position. If there were already 5 dominant bits straight bevore the defined position, the CAN nodes will detect a CAN-error after the first of the 6 dominant bits, and there will be a total of 11 dominant bits visible on the bus.
Regards, Gunnar Bohlen
bm_kamath
Post
by bm_kamath » Thu 25. May 2017, 10:51
Thanks Gunnar for the clarification ...
