I am trying to have an LED indicator turn on if any signal from a list of possible signals is received.
Eg. If any signal from "errorCode1", "errorCode2", "errorCode3", ... , "errorCoden" is received, the LED indicator must turn on.
All these signals have the same CAN ID if that matters.
Is this possible? I am using PCAN Explorer 5.
Sincerest thanks!
How to map multiple signals to one control
Re: How to map multiple signals to one control
yes, this will be possible by using a VBmacro, in which you set all three errorcodes to another virtual signal.
See example here: http://www.peak-system.com/forum/viewto ... p=421#p421
