How record data?
camiiiille
How record data?
Post by camiiiille » Thu 6. Jul 2017, 11:37
I am new in this forum. I have a Raspberry pi 3. I use correctly the driver and display data from the device with cat dev/pcan32
But I would like to know : could I record the data from the device connected with the PCAN-usb?
Camille
Re: How record data?
Post by PEAK-Support » Thu 6. Jul 2017, 15:13
if you use the CharDev (Character Device) driver you simply could pipe the output of the console to a text file.
camiiiille
Post by camiiiille » Mon 17. Jul 2017, 15:28
Is it possible to record automatically every received data from the device and using theterminal in the same time?
Post by PEAK-Support » Mon 17. Jul 2017, 15:30
Yes - use a second terminal instance
camiiiille
Post by camiiiille » Mon 17. Jul 2017, 16:36
With which tool can I record automatically data?
Post by PEAK-Support » Mon 17. Jul 2017, 16:42
If you use the CharDev (Character Device) driver you simply could pipe the output of the console to a text file.
If you use the SocketCAN (NetDev Device) driver you simply could use the Tool candump.
(see SocketCAN documentaion on GitHub)
