* Copyright (C) 2014 PEAK System-Technik GmbH
* linux@peak-system.com
* www.peak-system.com
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
* Maintainer(s): Stephane Grosjean (s.grosjean@peak-system.com)
* pcan_ucan.c - the uCAN firmware global interface
* $Id: pcan_ucan.c 615 2015-01-26 22:38:55Z stephane $
/*#define DEBUG*/
/*#undef DEBUG*/
//#define DEBUG_SLOW_BITTIMINGS
//#define DEBUG_FAST_BITTIMINGS
* INCLUDES
#include "src/pcan_common.h"
#include "src/pcan_main.h"
#include "src/pcanfd_core.h" /* uCAN base common messages */
#include "src/pcanfd_ucan.h" /* uCAN base common messages */
#ifdef USB_SUPPORT
#include "src/pcanfd_usb_fw.h" /* uCAN USB devices specific messages */
#endif
#ifdef NETDEV_SUPPORT
#include "src/pcan_netdev.h" /* for hotplug pcan_netdev_register() */
#else
#include <linux/can/dev.h>
#endif
#ifdef DEBUG
//#define DEBUG_BUS_LOAD /* very (VERY) verbose */
#define DEBUG_BUS_MODE
#define DEBUG_RX
#else
//#define DEBUG_RX
#endif
/* if defined, set the number of times an outgoing CAN message is repeated
* in the outgoing stream. This enables to do some internal tests only!
* This MUST not be defined in a production version! */
/* #define UCAN_TEST_TX_BURST 5 */
#ifndef get_can_dlc
/* some (very) old Kernels don't #define get_can_dlc() */
#define get_can_dlc(i) (min_t(__u8, (i), 8))
#endif
/* Adapter timinig capabilities */
static const struct pcanfd_bittiming_range ucan_slow_capabilities = {
.brp_min = 1,
.brp_max = (1 << UCAN_TSLOW_BRP_BITS),
.brp_inc = 1,
.tseg1_min = 1,
.tseg1_max = (1 << UCAN_TSLOW_TSGEG1_BITS), // 64 or 256
.tseg2_min = 1,
.tseg2_max = (1 << UCAN_TSLOW_TSGEG2_BITS), // 16 or 128
.sjw_min = 1,
.sjw_max = (1 << UCAN_TSLOW_SJW_BITS) // 16 or 128
static const struct pcanfd_bittiming_range ucan_fast_capabilities = {
.brp_min = 1,
.brp_max = (1 << UCAN_TFAST_BRP_BITS),
.brp_inc = 1,
.tseg1_min = 1,
.tseg1_max = (1 << UCAN_TFAST_TSGEG1_BITS), // 16 or 32
.tseg2_min = 1,
.tseg2_max = (1 << UCAN_TFAST_TSGEG2_BITS), // 8 or 16
.sjw_min = 1,
.sjw_max = (1 << UCAN_TFAST_SJW_BITS) // 4 or 16
typedef struct __array_of_struct(pcanfd_available_clock, 6)
pcanfd_6_clocks_device;
static const pcanfd_6_clocks_device ucan_clocks = {
.count = 6,
.list = {
[0] = { .clock_Hz = 80*MHz, .clock_src = 80*MHz, },
[1] = { .clock_Hz = 20*MHz, .clock_src = 240*MHz, },
[2] = { .clock_Hz = 24*MHz, .clock_src = 240*MHz, },
[3] = { .clock_Hz = 30*MHz, .clock_src = 240*MHz, },
[4] = { .clock_Hz = 40*MHz, .clock_src = 240*MHz, },
[5] = { .clock_Hz = 60*MHz, .clock_src = 240*MHz, },
static const u8 pcan_fd_dlc2len[] = {
0, 1, 2, 3, 4, 5, 6, 7,
8, 12, 16, 20, 24, 32, 48, 64
/* get data length from can_dlc with sanitized can_dlc */
static u8 pcan_dlc2len(u8 can_dlc)
return pcan_fd_dlc2len[can_dlc & 0x0F];
static const u8 pcan_fd_len2dlc[] = {
0, 1, 2, 3, 4, 5, 6, 7, 8, /* 0 - 8 */
9, 9, 9, 9, /* 9 - 12 */
10, 10, 10, 10, /* 13 - 16 */
11, 11, 11, 11, /* 17 - 20 */
12, 12, 12, 12, /* 21 - 24 */
13, 13, 13, 13, 13, 13, 13, 13, /* 25 - 32 */
14, 14, 14, 14, 14, 14, 14, 14, /* 33 - 40 */
14, 14, 14, 14, 14, 14, 14, 14, /* 41 - 48 */
15, 15, 15, 15, 15, 15, 15, 15, /* 49 - 56 */
15, 15, 15, 15, 15, 15, 15, 15 /* 57 - 64 */
/* map the sanitized data length to an appropriate data length code */
static u8 pcan_len2dlc(u8 len)
if (len > 64)
return 0xF;
return pcan_fd_len2dlc[len];
struct pcandev *ucan_init_cmd(struct pcandev *dev)
dev->ucan.cmd_len = 0;
return dev;
void *ucan_add_cmd(struct pcandev *dev, int cmd_op)
const int cmd_size = sizeof(u64);
struct ucan_command *cmd;
if (dev->ucan.cmd_len + cmd_size > dev->ucan.cmd_size) {
#ifdef DEBUG_ALL
pr_err("%s: %s(): failed to add cmd %03xh: "
"device cmd buffer not large enough (%u+%u > %u)\n",
DEVICE_NAME, __func__, cmd_op,
dev->ucan.cmd_len, cmd_size, dev->ucan.cmd_size);
#endif
return NULL;
cmd = dev->ucan.cmd_head + dev->ucan.cmd_len;
/* unused bits should be 0 */
*(u64 *)cmd = 0;
cmd->opcode_channel = UCAN_CMD_OPCODE_CHANNEL(dev->nChannel, cmd_op);
dev->ucan.cmd_len += cmd_size;
return cmd;
/* uCAN commands interface functions */
void *ucan_add_cmd_nop(struct pcandev *dev)
return ucan_add_cmd(dev, UCAN_CMD_NOP);
static void *ucan_add_cmd_reset_mode(struct pcandev *dev)
return ucan_add_cmd(dev, UCAN_CMD_RESET_MODE);
static void *ucan_add_cmd_normal_mode(struct pcandev *dev)
return ucan_add_cmd(dev, UCAN_CMD_NORMAL_MODE);
static void *ucan_add_cmd_listen_only_mode(struct pcandev *dev)
return ucan_add_cmd(dev, UCAN_CMD_LISTEN_ONLY_MODE);
static void *ucan_add_cmd_timing_slow(struct pcandev *dev,
struct pcan_bittiming *pbr)
struct ucan_timing_slow *cmd = ucan_add_cmd(dev, UCAN_CMD_TIMING_SLOW);
if (cmd) {
#if 0
pbr->brp = 10;
pbr->tseg1 = 5;
pbr->tseg2 = 2;
#endif
#ifdef DEBUG_SLOW_BITTIMINGS
pr_info(DEVICE_NAME ": %s CAN%u = SLOW"
"[brp=%u tseg1=%u tseg2=%u sjw=%u ts=%u]\n",
dev->adapter->name, dev->nChannel+1,
pbr->brp, pbr->tseg1, pbr->tseg2, pbr->sjw, pbr->tsam);
#endif
cmd->sjw_t = UCAN_TSLOW_SJW_T(pbr->sjw - 1, pbr->tsam);
cmd->tseg1 = UCAN_TSLOW_TSEG1(pbr->tseg1 - 1);
cmd->tseg2 = UCAN_TSLOW_TSEG2(pbr->tseg2 - 1);
cmd->brp = UCAN_TSLOW_BRP(pbr->brp - 1);
cmd->ewl = 96; /* default */
return cmd;
static void *ucan_add_cmd_timing_fast(struct pcandev *dev,
struct ucan_timing_fast *cmd = ucan_add_cmd(dev, UCAN_CMD_TIMING_FAST);
if (cmd) {
#ifdef DEBUG_FAST_BITTIMINGS
pr_info(DEVICE_NAME ": %s CAN%u = FAST"
"[brp=%u tseg1=%u tseg2=%u sjw=%u]\n",
pbr->brp, pbr->tseg1, pbr->tseg2, pbr->sjw);
#endif
cmd->sjw = UCAN_TFAST_SJW(pbr->sjw - 1);
cmd->tseg1 = UCAN_TFAST_TSEG1(pbr->tseg1 - 1);
cmd->tseg2 = UCAN_TFAST_TSEG2(pbr->tseg2 - 1);
cmd->brp = UCAN_TFAST_BRP(pbr->brp - 1);
return cmd;
static void *ucan_add_cmd_tx_abort(struct pcandev *dev, u16 flags)
struct ucan_tx_abort *cmd = ucan_add_cmd(dev, UCAN_CMD_TX_ABORT);
if (cmd)
cmd->flags = cpu_to_le16(flags);
return cmd;
static void *ucan_add_cmd_rx_barrier(struct pcandev *dev)
return ucan_add_cmd(dev, UCAN_CMD_RX_BARRIER);
static void *ucan_add_cmd_wr_err_cnt(struct pcandev *dev, u16 sel_mask,
u8 tx_counter, u8 rx_counter)
struct ucan_wr_err_cnt *cmd = ucan_add_cmd(dev, UCAN_CMD_WR_ERR_CNT);
if (cmd) {
cmd->sel_mask = cpu_to_le16(sel_mask);
cmd->tx_counter = tx_counter;
cmd->rx_counter = rx_counter;
return cmd;
void *ucan_add_cmd_set_en_option(struct pcandev *dev, u16 mask)
struct ucan_option *cmd = ucan_add_cmd(dev, UCAN_CMD_SET_EN_OPTION);
if (cmd)
cmd->mask = cpu_to_le16(mask);
return cmd;
void *ucan_add_cmd_clr_dis_option(struct pcandev *dev, u16 mask)
struct ucan_option *cmd = ucan_add_cmd(dev, UCAN_CMD_CLR_DIS_OPTION);
if (cmd)
return cmd;
/* pcan interface functions */
int ucan_clr_err_counters(struct pcandev *dev)
#ifdef DEBUG
pr_info("%s: %s()\n", DEVICE_NAME, __func__);
#endif
if (!ucan_add_cmd_wr_err_cnt(ucan_init_cmd(dev),
UCAN_WRERRCNT_TE|UCAN_WRERRCNT_RE, 0, 0))
return -EINVAL;
dev->tx_error_counter = 0;
dev->rx_error_counter = 0;
/* send the command */
return dev->ucan.ops->send_cmd(dev);
/* int ucan_set_all_acceptance_filter(struct pcandev *dev)
struct ucan_std_filter *cmd = NULL;
const int n = 1 << UCAN_FLTSTD_ROW_IDX_BITS;
int i, err;
#ifdef DEBUG
#endif
/* build (and send) a command for each row */
ucan_init_cmd(dev);
for (i = 0; i < n; i++) {
while (1) {
cmd = ucan_add_cmd(dev, UCAN_CMD_SET_STD_FILTER);
if (cmd)
break;
/* not enough room? 1st, send the cmds */
err = dev->ucan.ops->send_cmd(dev);
if (err)
return err;
/* next, reset the cmd buffer and retry */
ucan_init_cmd(dev);
cmd->idx = i;
cmd->mask = cpu_to_le32(0xffffffff);
/* send the commands */
/* int ucan_set_msg_filters(struct pcandev *dev, u16 mask)
#ifdef DEBUG
#endif
if (!ucan_add_cmd_set_en_option(ucan_init_cmd(dev), mask))
return -EINVAL;
/* int ucan_clr_msg_filters(struct pcandev *dev, u16 mask)
#ifdef DEBUG
#endif
if (!ucan_add_cmd_clr_dis_option(ucan_init_cmd(dev), mask))
return -EINVAL;
/* int ucan_tx_abort(struct pcandev *dev, u16 flags)
#ifdef DEBUG
pr_info("%s: %s(CAN%u, flags=%04xh)\n",
DEVICE_NAME, __func__, dev->nChannel+1, flags);
#endif
if (!ucan_add_cmd_tx_abort(ucan_init_cmd(dev), flags))
return -EINVAL;
/* int ucan_rx_barrier(struct pcandev *dev)
#ifdef DEBUG
pr_info("%s: %s(CAN%u)\n", DEVICE_NAME, __func__, dev->nChannel+1);
#endif
if (!ucan_add_cmd_rx_barrier(ucan_init_cmd(dev)))
return -EINVAL;
static int ucan_convert_BTR0BTR1(u16 btr0btr1,
const struct pcanfd_bittiming_range *pcap,
struct pcan_bittiming_abs at_original, at_convert;
const u32 sysclock = 80*MHz;
pcan_btr0btr1_to_abstract(&at_original, btr0btr1);
if (!pcan_convert_abstract(&at_convert, &at_original, pcap, sysclock))
return -EINVAL;
return pcan_abstract_to_bittiming(pbr, &at_convert, pcap, sysclock);
/* int ucan_set_bus_on(struct pcandev *dev)
* Set uCAN device bus controller to ON.
int err;
void *cmd = (dev->flags & PCAN_DEV_LISTEN_ONLY) ?
ucan_add_cmd_listen_only_mode(ucan_init_cmd(dev)) :
ucan_add_cmd_normal_mode(ucan_init_cmd(dev));
#ifdef DEBUG_BUS_MODE
pr_info(DEVICE_NAME ": %s(%s CAN%u): %s\n",
__func__, dev->adapter->name, dev->nChannel+1,
"LISTEN_ONLY" : "NORMAL");
#endif
if (!cmd)
return -EINVAL;
if (!err)
dev->flags |= PCAN_DEV_BUS_ON;
return err;
/* int ucan_set_bus_off(struct pcandev *dev)
* Set uCAN device bus controller to OFF.
int err;
#ifdef DEBUG
#endif
if (!ucan_add_cmd_reset_mode(ucan_init_cmd(dev)))
return -EINVAL;
/* wait a bit for last data to be written on CAN bus
* (5 ms is not enough if any data buffer was almost filled)
* This delay is mandatory when going to BUS_OFF with uCAN devices.
* (10 ms is enough for USB devices but not for PCI devices) */
if (dev->tx_frames_counter > 0)
mdelay(50);
if (!err)
dev->flags &= ~PCAN_DEV_BUS_ON;
return err;
int ucan_set_options(struct pcandev *dev, u16 opt_mask)
#ifdef DEBUG
pr_info("%s: %s(CAN%u, mask=%04xh)\n",
DEVICE_NAME, __func__, dev->nChannel+1, opt_mask);
#endif
if (!ucan_add_cmd_set_en_option(ucan_init_cmd(dev), opt_mask))
return -EINVAL;
int ucan_clr_options(struct pcandev *dev, u16 opt_mask)
#ifdef DEBUG
#endif
if (!ucan_add_cmd_clr_dis_option(ucan_init_cmd(dev), opt_mask))
return -EINVAL;
/* int ucan_set_timing_slow(struct pcandev *dev,
* struct pcan_bittiming *pbr)
static int ucan_set_timing_slow(struct pcandev *dev,
#ifdef DEBUG
pr_info("%s: %s(CAN%u, btr=%d brp=%d tseg1=%d tseg2=%d "
"sjw=%d tsam=%d)\n", DEVICE_NAME, __func__, dev->nChannel+1,
pbr->bitrate, pbr->brp, pbr->tseg1, pbr->tseg2, pbr->sjw,
pbr->tsam);
#endif
if (!ucan_add_cmd_timing_slow(ucan_init_cmd(dev), pbr))
return -EINVAL;
/* int ucan_set_timing_fast(struct pcandev *dev,
static int ucan_set_timing_fast(struct pcandev *dev,
#ifdef DEBUG
pbr->tsam);
#endif
if (!ucan_add_cmd_timing_fast(ucan_init_cmd(dev), pbr))
return -EINVAL;
static inline int ucan_set_iso_mode(struct pcandev *dev)
#ifdef DEBUG
#endif
return ucan_set_options(dev, UCAN_OPTION_ISO_MODE);
static inline int ucan_clr_iso_mode(struct pcandev *dev)
#ifdef DEBUG
#endif
return ucan_clr_options(dev, UCAN_OPTION_ISO_MODE);
#if 0
#define BTR0BTR1_1MBPS 0x0014
#define BTR0BTR1_500KBPS 0x001c
#define BTR0BTR1_250KBPS 0x011c
#endif
/* int ucan_set_BTR0BTR1(struct pcandev *dev, u16 btr0btr1)
struct pcan_bittiming bitrate;
#ifdef DEBUG
#endif
switch (btr0btr1) {
#ifdef BTR0BTR1_1MBPS
case BTR0BTR1_1MBPS:
bitrate.tsam = 0;
bitrate.sjw = 1;
bitrate.tseg1 = 29;
bitrate.tseg2 = 10;
bitrate.brp = 2;
break;
#endif
#ifdef BTR0BTR1_500KBPS
case BTR0BTR1_500KBPS:
bitrate.tsam = 0;
bitrate.sjw = 1;
bitrate.tseg1 = 34;
bitrate.tseg2 = 5;
bitrate.brp = 4;
break;
#endif
default:
/* Need to convert this value for PCAN-USB (Pro) FD */
if (!ucan_convert_BTR0BTR1(btr0btr1,
&ucan_slow_capabilities, &bitrate)) {
pr_err("%s: unable to convert BTR0BTR1 0x%04x\n",
DEVICE_NAME, btr0btr1);
pr_err("%s: won't be able to transfer data on CAN#%d\n",
DEVICE_NAME, dev->nChannel);
return -EINVAL;
return ucan_set_timing_slow(dev, &bitrate);
int ucan_soft_init(struct pcandev *dev, char *szType, u16 wType)
#ifdef DEBUG
pr_info("%s: %s(%s, %02Xh)\n", DEVICE_NAME, __func__, szType, wType);
#endif
pcan_soft_init_ex(dev, szType, wType,
(const struct pcanfd_available_clocks *)&ucan_clocks,
PCAN_DEV_BUSLOAD_RDY|PCAN_DEV_ERRCNT_RDY);
dev->def_init_settings.flags |= PCANFD_INIT_FD;
dev->dbittiming_caps = &ucan_fast_capabilities;
pcan_bittiming_normalize(&dev->def_init_settings.data,
dev->sysclock_Hz,
&ucan_fast_capabilities);
/* reset default init settings with new data bitrate specs */
dev->init_settings = dev->def_init_settings;
return 0;
/* pcan (chardev) interface */
int ucan_device_open(struct pcandev *dev, u16 btr0btr1, u8 ext, u8 listen_only)
int err;
/* reset error counters */
err = ucan_clr_err_counters(dev);
if (err)
goto fail;
err = ucan_set_BTR0BTR1(dev, btr0btr1);
if (err)
goto fail;
/* Set filter mode: accept all */
err = ucan_set_all_acceptance_filter(dev);
if (err)
goto fail;
/* keep in memory listen only mode (set when bus goes on) */
if (listen_only)
dev->flags |= PCAN_DEV_LISTEN_ONLY;
else
dev->flags &= ~PCAN_DEV_LISTEN_ONLY;
fail:
return err;
static int ucan_set_clock_domain(struct pcandev *dev, struct pcanfd_init *pfdi)
int err = 0;
/* set the uCAN clock domain */
if (dev->ucan.ops->set_clk_domain) {
err = dev->ucan.ops->set_clk_domain(dev, pfdi);
/* looks like pfdi->clock_Hz was wrong: it must be
* reset to its default value and the bittimings must be
* computed accordingly and the clock domain reset as well. */
if (err == -EINVAL) {
/* uCAN device default clock value */
pfdi->clock_Hz = ucan_clocks.list[0].clock_Hz;
/* use bitrate bps value as reference to rebuild BRP,
* TSEGx and SJW accroding to the de fault clock */
pcan_bitrate_to_bittiming(&pfdi->nominal,
dev->bittiming_caps,
pfdi->clock_Hz);
if (pfdi->flags & PCANFD_INIT_FD)
pcan_bitrate_to_bittiming(&pfdi->data,
dev->dbittiming_caps,
pfdi->clock_Hz);
/* finaly, reset to default clock domain */
return err;
/* pcanfd (chardev) interface */
int ucan_device_open_fd(struct pcandev *dev, struct pcanfd_init *pfdi)
int err;
err = ucan_set_clock_domain(dev, pfdi);
if (err)
goto fail;
if (err)
goto fail;
if (pfdi->flags & PCANFD_INIT_FD) {
if (pfdi->flags & PCANFD_INIT_FD_NON_ISO) {
err = ucan_clr_iso_mode(dev);
} else {
err = ucan_set_iso_mode(dev);
if (err)
goto fail;
err = ucan_set_timing_fast(dev, &pfdi->data);
if (err)
goto fail;
err = ucan_set_timing_slow(dev, &pfdi->nominal);
if (err)
goto fail;
if (err)
goto fail;
if (pfdi->flags & PCANFD_INIT_LISTEN_ONLY)
else
fail:
return err;
/* int ucan_reset_path(struct pcandev *dev)
* After reset, the CAN core stays active.
int err;
/* reset the Tx path first */
err = ucan_tx_abort(dev, UCAN_TX_ABORT_FLUSH);
if (err)
goto fail;
/* reset the Rx path next */
err = ucan_rx_barrier(dev);
fail:
return err;
/* int ucan_post_canrx_msg(struct pcandev *dev,
* struct ucan_rx_msg *rm, struct timeval *ptv)
* Default handler of incoming CAN messages
struct pcanfd_msg f;
const u16 msg_flags = le16_to_cpu(rm->flags);
int err;
#ifdef DEBUG_RX
printk(KERN_DEBUG "%s: %s(CAN%u): wCANStatus=%xh "
"rx=[flags=0x%02x len=0x%02x ts32=0x%08x id=0x%08x]\n",
dev->wCANStatus, msg_flags, UCAN_MSG_DLC(rm),
le32_to_cpu(rm->ts_low), le32_to_cpu(rm->can_id));
#endif
/* sure we are no more in that sate */
//dev->wCANStatus &= ~CAN_ERR_QOVERRUN;
pcan_clear_status_bit(dev, CAN_ERR_QOVERRUN);
#if 1
/* such test is now made by pcan_chardev_rx() func */
#else
/* Don't send any message when device not opened */
if (dev->nOpenPaths <= 0) {
pr_info("%s: incoming message 0x%x (flags=%x) discarded: "
"CAN#%d not yet opened\n",
DEVICE_NAME, le32_to_cpu(rm->can_id), rm->flags,
UCAN_MSG_CHANNEL(rm));
return 0;
#endif
/* ignore any CAN data while we're in BUSOFF */
//if (dev->wCANStatus & CAN_ERR_BUSOFF)
switch (dev->bus_state) {
case PCANFD_UNKNOWN:
case PCANFD_ERROR_BUSOFF:
#ifdef DEBUG_RX
pr_info(DEVICE_NAME
": %s(CAN%u): rx CAN msg discarded (bus_state=%u)\n",
__func__, dev->nChannel+1, dev->bus_state);
#endif
return 0;
default:
break;
memset(&f, '\0', sizeof(f));
if (msg_flags & UCAN_MSG_EXT_DATA_LEN) {
/* CAN FD frame */
f.type = PCANFD_TYPE_CANFD_MSG;
if (msg_flags & UCAN_MSG_BITRATE_SWITCH)
f.flags |= PCANFD_MSG_BRS;
if (msg_flags & UCAN_MSG_ERROR_STATE_IND)
f.flags |= PCANFD_MSG_ESI;
f.data_len = pcan_dlc2len(UCAN_MSG_DLC(rm));
} else {
/* CAN 2.0 frame */
f.type = PCANFD_TYPE_CAN20_MSG;
f.data_len = get_can_dlc(UCAN_MSG_DLC(rm));
f.id = le32_to_cpu(rm->can_id);
if (ptv) {
f.flags |= PCANFD_TIMESTAMP|PCANFD_HWTIMESTAMP;
f.timestamp = *ptv;
#ifdef PCANFD_RAWTIMESTAMP
f.flags |= PCANFD_RAWTIMESTAMP;
f.raw_timestamp = ((u64 )le32_to_cpu(rm->ts_high) << 32) |
le32_to_cpu(rm->ts_low);
#endif
if (msg_flags & UCAN_MSG_EXT_ID)
f.flags |= PCANFD_MSG_EXT;
if (msg_flags & UCAN_MSG_RTR)
f.flags |= PCANFD_MSG_RTR;
else
memcpy(f.data, rm->d, f.data_len);
if (msg_flags & UCAN_MSG_HW_SRR)
f.flags |= PCANFD_MSG_SLF;
#ifdef DEBUG_RX
dump_mem("posted pcanfd_msg", &f, sizeof(struct pcanfd_msg));
#endif
err = pcan_xxxdev_rx(dev, &f);
if (err < 0)
pr_err(DEVICE_NAME
": %s CAN%u: CAN msg %xh (l=%u) lost (err %d)\n",
f.id, f.data_len, err);
return err;
/* int ucan_handle_error(struct ucan_engine *ucan,
* struct ucan_msg *rx_msg, void *arg)
* Default handler of incoming error messages
/* WARNING: ucan pointer can be NULL! */
struct ucan_error_msg *er = (struct ucan_error_msg *)rx_msg;
struct pcandev *dev = (struct pcandev *)arg;
#ifdef DEBUG
printk(KERN_DEBUG "%s: %s(): "
"rx=[type=0x%02x ts32=0x%08x d=%u g=%u code=0x%02x "
"err_cnt[rx=%u tx=%u]]\n",
UCAN_ERMSG_ERRTYPE(er), le32_to_cpu(er->ts_low),
UCAN_ERMSG_D(er)?1:0,
UCAN_ERMSG_G(er)?1:0,
UCAN_ERMSG_ERRCODE(er),
er->rx_err_cnt, er->tx_err_cnt);
#endif
/* keep a trace of tx and rx error counters for later use */
dev->rx_error_counter = er->rx_err_cnt;
dev->tx_error_counter = er->tx_err_cnt;
#ifdef DEBUG
if (dev->rx_error_counter || dev->tx_error_counter)
printk(KERN_ERR
"%s: %s CAN%u: errors: rx=%u tx=%u\n",
DEVICE_NAME, dev->adapter->name, dev->nChannel,
dev->rx_error_counter, dev->tx_error_counter);
#endif
return 0;
int ucan_post_error_msg(struct pcandev *dev,
struct ucan_error_msg *er, struct timeval *ptv)
#ifdef DEBUG
#endif
/* call default handler first */
ucan_handle_error(NULL, (struct ucan_msg *)er, dev);
#if 0
/* don't bother user with messages having the same status */
if ((dev->tx_error_counter == er->tx_err_cnt) &&
(dev->rx_error_counter == er->rx_err_cnt))
return 0;
#endif
f.type = PCANFD_TYPE_STATUS;
f.flags = PCANFD_ERROR_BUS;
f.id = dev->bus_state;
if (ptv) {
f.timestamp = *ptv;
return pcan_xxxdev_rx(dev, &f);
int ucan_post_status_msg(struct pcandev *dev,
struct ucan_status_msg *st, struct timeval *ptv)
#ifdef DEBUG
printk(KERN_DEBUG "%s: %s(CAN%u): bus_state=%u "
"ts32=0x%08x EP=%u EW=%u BO=%u]\n",
DEVICE_NAME,__func__, dev->nChannel+1, dev->bus_state,
le32_to_cpu(st->ts_low), !!UCAN_STMSG_PASSIVE(st),
!!UCAN_STMSG_WARNING(st), !!UCAN_STMSG_BUSOFF(st));
#endif
if (UCAN_STMSG_BUSOFF(st)) {
pcan_handle_busoff(dev, &f);
} else if (!pcan_handle_error_status(dev, &f, UCAN_STMSG_WARNING(st),
UCAN_STMSG_PASSIVE(st))) {
/* no error bit (so, no error, back to active state) */
pcan_handle_error_active(dev, &f);
if (f.type == PCANFD_TYPE_NOP) {
#ifdef DEBUG
pr_info(DEVICE_NAME ": %s(CAN%u): status msg discarded (NOP)\n",
#endif
return 0;
if (ptv) {
f.timestamp = *ptv;
* int ucan_handle_bus_load(struct ucan_engine *ucan,
* Default handler for bus_load notification messages.
struct ucan_bus_load_msg *bl = (struct ucan_bus_load_msg *)rx_msg;
#ifdef DEBUG_BUS_LOAD
"ts32=0x%08x bus_load=%u\n",
le32_to_cpu(bl->ts_low), le16_to_cpu(bl->bus_load));
#endif
//dev->bus_load = (100 * le16_to_cpu(bl->bus_load)) / 4095;
dev->bus_load = (10000 * le16_to_cpu(bl->bus_load)) / 4095;
return 0;
int ucan_post_bus_load_msg(struct pcandev *dev,
struct ucan_bus_load_msg *bl, struct timeval *ptv)
#if 0//def DEBUG
printk(KERN_DEBUG "%s: %s(%s CAN%d)\n", DEVICE_NAME, __func__,
dev->adapter->name, dev->nChannel+1);
#endif
/* call default handler */
ucan_handle_bus_load(NULL, (struct ucan_msg *)bl, dev);
f.id = PCANFD_BUS_LOAD;
if (ptv) {
f.timestamp = *ptv;
int ucan_post_overflow_msg(struct pcandev *dev, struct timeval *ptv)
#ifdef DEBUG
printk(KERN_DEBUG "%s: %s()\n", DEVICE_NAME, __func__);
#endif
dev->dwErrorCounter++;
/* do some filter to avoid overflowing rx queue with the same STATUS
* messages */
if (dev->wCANStatus & CAN_ERR_QOVERRUN)
return 0;
dev->wCANStatus |= CAN_ERR_QOVERRUN;
f.flags = PCANFD_ERROR_CTRLR;
f.id = PCANFD_RX_OVERFLOW;
if (ptv) {
f.timestamp = *ptv;
int ucan_handle_msg(struct ucan_engine *ucan, void *msg_addr)
struct ucan_msg *msg;
void *arg = NULL;
int msg_size;
u16 msg_type;
int ci = -1, err;
int (*msg_cb)(struct ucan_engine *, struct ucan_msg *, void *);
msg = (struct ucan_msg *)msg_addr;
msg_size = le16_to_cpu(msg->size);
if (!msg->size || !msg->type) {
/* null packet found: end of list */
goto lbl_return;
msg_type = le16_to_cpu(msg->type);
#ifdef DEBUG_RX
switch (msg_type) {
#ifdef USB_SUPPORT
case UCAN_USB_MSG_CALIBRATION:
#endif
#ifndef DEBUG_BUS_LOAD
case UCAN_MSG_BUSLOAD:
#endif
case UCAN_MSG_ERROR:
break;
default:
dump_mem("received msg", msg, msg_size);
#endif
/* theses msgs carry a channel index */
switch (msg_type) {
case UCAN_MSG_CAN_RX:
ci = UCAN_MSG_CHANNEL((struct ucan_rx_msg *)msg);
break;
ci = UCAN_ERMSG_CHANNEL((struct ucan_error_msg *)msg);
break;
case UCAN_MSG_STATUS:
ci = UCAN_STMSG_CHANNEL((struct ucan_status_msg *)msg);
break;
ci = UCAN_BLMSG_CHANNEL((struct ucan_bus_load_msg *)msg);
break;
#ifdef USB_SUPPORT
arg = pcan_usb_get_if(&ucan->devs[0]);
break;
case UCAN_USB_MSG_OVERRUN:
ci = UCAN_USB_OVMSG_CHANNEL((struct ucan_usb_ovr_msg *)msg);
break;
#endif
if (msg_type < ucan->ops->handle_msg_size) {
if (!ucan->ops->handle_msg_table[msg_type]) {
pr_info(DEVICE_NAME ": unhandled rx uCAN msg %03xh: "
"it is ignored\n", msg_type);
dump_mem("unhandled msg", msg, msg_size);
goto lbl_return;
msg_cb = ucan->ops->handle_msg_table[msg_type];
} else {
if (!ucan->ops->handle_private_msg) {
pr_err(DEVICE_NAME ": out of range rx uCAN msg "
"%03xh >= %u: it is ignored\n", msg_type,
ucan->ops->handle_msg_size);
dump_mem("out of range msg", msg, msg_size);
goto lbl_return;
/* note: in that case, ci is always -1... */
msg_cb = ucan->ops->handle_private_msg;
if (ci != -1) {
/* be sure of the index read... */
if ((ci < 0) || (ci >= ucan->devs_count)) {
#ifdef DEBUG
pr_info(DEVICE_NAME ": invalid channel %d in uCAN "
"msg %03xh: it is ignored\n", ci, msg_type);
#endif
goto lbl_return;
arg = ucan->devs + ci;
//err = ucan->ops->handle_msg_table[msg_type](ucan, msg, arg);
err = msg_cb(ucan, msg, arg);
if (err < 0)
return err;
lbl_return:
return msg_size;
/* int ucan_handle_msgs_buffer(struct ucan_engine *ucan, void *msg_addr,
* int msg_len)
int msg_len)
u8 *msg_end = msg_addr + msg_len;
int msg_size = 0;
u8 *msg_ptr;
#if 0//def DEBUG
pr_info("%s: %s(%d)\n", DEVICE_NAME, __func__, msg_len);
//dump_mem("received msg", msg_addr, msg_len);
#endif
/* loop reading all the records from the incoming message */
for (msg_ptr = msg_addr; msg_ptr < msg_end; msg_ptr += msg_size) {
msg_size = ucan_handle_msg(ucan, msg_ptr);
/* a null packet can be found at the end of a list */
if (msg_size <= 0)
break;
#if 0
pr_info("%s: %s(): found %u msgs in %u bytes buffer\n",
DEVICE_NAME, __func__, msg_nb, msg_len);
#endif
/* check if the record goes out of current packet */
if (msg_ptr > msg_end) {
/* yes, it does: donot handle fragmentation => increase usb rx
* message size */
printk(KERN_ERR
"%s: got frag rec: should inc rx buffer size\n",
DEVICE_NAME);
msg_size = -EBADMSG;
/* in case of error, dump the whole messages (list) */
if (msg_size < 0) {
if (msg_size != -ENOSPC)
dump_mem("received err msg", msg_addr, msg_len);
return msg_size;
return 0;
* int ucan_handle_msgs_list(struct ucan_engine *ucan, void *msg_addr,
* int *msg_count)
int *msg_count)
u8 *msg_ptr = msg_addr;
int msg_len = 0;
int msg_size = 0;
int i;
#if 0//def DEBUG
pr_info("%s: %s(%d)\n", DEVICE_NAME, __func__, *msg_count);
#endif
for (i = 0; i < *msg_count; i++) {
if (msg_size <= 0)
break;
msg_len += msg_size;
msg_ptr += msg_size;
*msg_count = i;
/* in case of error, dump the whole messages (list),
* except in case of not enough space in Rx FIFO... */
if (msg_size < 0) {
return msg_size;
return 0;
* int ucan_encode_msg(struct pcandev *dev, u8 *buffer_addr, int buffer_size)
struct ucan_tx_msg *tx_msg = (struct ucan_tx_msg *)buffer_addr;
struct pcanfd_msg can_msg;
int tx_msg_size, err, dlc;
u16 tx_flag_tmp = 0x0;
#ifdef UCAN_TEST_TX_BURST
int i;
#endif
/* first get the size of the enqueued CAN message */
err = pcan_fifo_peek(&dev->writeFifo, &can_msg);
if (err) {
if (err != -ENODATA) {
printk(KERN_ERR "%s: %s(): "
"can't get data out of writeFifo, "
"available data: %d, err: %d\n",
dev->writeFifo.nStored, err);
return err;
#ifdef DEBUG
printk(KERN_DEBUG "Encoding msg {type=%u id=%xh dlen=%u flg=%xh}\n",
can_msg.type, can_msg.id, can_msg.data_len, can_msg.flags);
#endif
#if 1
/* TODO: is this test really needed ? May the Tx fifo contain other
* messages than CAN frames ? */
#else
#ifdef MSGTYPE_PARAMETER
if (can_msg.flags & (PCANFD_ERROR_STATUS | MSGTYPE_PARAMETER)) {
#else
if (can_msg.flags & PCANFD_ERROR_STATUS) {
#endif
printk(KERN_INFO "%s: %s(): "
"CAN msg type %08Xh ignored\n",
DEVICE_NAME, __func__, can_msg.flags);
return 0;
#endif
dlc = pcan_len2dlc(can_msg.data_len);
tx_msg_size = ALIGN(sizeof(struct ucan_tx_msg)+ pcan_dlc2len(dlc), 4);
tx_msg_size *= UCAN_TEST_TX_BURST;
#endif
/* if not enough room to entirely copy it, stop here */
if (tx_msg_size > buffer_size) {
#ifdef DEBUG
"%u bytes left too small for storing %u bytes\n",
buffer_size, tx_msg_size);
#endif
return -ENOSPC;
/* really read the message (NULL avoid 2nd useless memcpy()) */
pcan_fifo_get(&dev->writeFifo, NULL);
tx_msg_size /= UCAN_TEST_TX_BURST;
for (i = 0; i < UCAN_TEST_TX_BURST; i++ ) {
#endif
memset(tx_msg, '\0', tx_msg_size);
tx_msg->type = cpu_to_le16(UCAN_MSG_CAN_TX);
tx_msg->size = cpu_to_le16(tx_msg_size);
//tx_msg->flags = 0;
if (can_msg.flags & PCANFD_MSG_EXT) {
tx_flag_tmp |= UCAN_MSG_EXT_ID;
tx_msg->can_id = cpu_to_le32(can_msg.id & CAN_EFF_MASK);
} else {
tx_msg->can_id = cpu_to_le32(can_msg.id & CAN_SFF_MASK);
switch (can_msg.type) {
case PCANFD_TYPE_CANFD_MSG:
/* CAN-FD frames */
tx_flag_tmp |= UCAN_MSG_EXT_DATA_LEN;
if (can_msg.flags & PCANFD_MSG_BRS)
tx_flag_tmp |= UCAN_MSG_BITRATE_SWITCH;
if (can_msg.flags & PCANFD_MSG_ESI)
tx_flag_tmp |= UCAN_MSG_ERROR_STATE_IND;
tx_msg->flags = cpu_to_le16(tx_flag_tmp);
break;
case PCANFD_TYPE_CAN20_MSG:
/* CAN 2.0 frames */
if (can_msg.flags & PCANFD_MSG_RTR)
tx_flag_tmp |= UCAN_MSG_RTR;
if (can_msg.flags & PCANFD_MSG_SLF)
tx_flag_tmp |= UCAN_MSG_HW_SRR;
break;
tx_msg->channel_dlc = UCAN_MSG_CHANNEL_DLC(dev->nChannel, dlc);
memcpy(tx_msg->d, can_msg.data, can_msg.data_len);
tx_msg->d[0] = (u8 )i;
buffer_addr += tx_msg_size;
#endif
return tx_msg_size;
* int ucan_encode_msgs_buffer(struct pcandev *dev,
* u8 *buffer_addr, int *buffer_size)
* Read msgs from CAN Tx fifo and encode them into the given buffer.
* -ENODATA if no more data in CAN fifo,
* -ENOSPC if *buffer_size is not large enough to store a TX_x
* record
* any other -ERR.
* >= 0 if output buffer is full of TX_x records,
int ucan_encode_msgs_buffer(struct pcandev *dev, u8 *buffer_addr,
int *buffer_size)
int msg_len, msg_count;
int err = 0;
#ifdef DEBUG
#endif
for (msg_len = msg_count = 0; msg_len < *buffer_size; ) {
err = ucan_encode_msg(dev, buffer_addr + msg_len,
*buffer_size - msg_len);
if (err < 0) {
#ifdef DEBUG
printk(KERN_DEBUG "%s: %s(): err %d while encoding msg "
"*buffer_size=%d msg_len=%d msg_count=%d\n",
DEVICE_NAME, __func__, err,
*buffer_size, msg_len, msg_count);
#endif
break;
/* to be sure to not count other msgs than CAN frames */
if (!err)
continue;
msg_len += err;
msg_count++;
if (!msg_len) {
*buffer_size = 0;
return -ENODATA;
/* if the entire packet is not filled, set the size of last msg to 0
* to mark end-of-rec
if (msg_len < *buffer_size) {
*(u32 *)(buffer_addr + msg_len) = 0;
msg_len += sizeof(u32);
/* set the whole size of the packet to send */
*buffer_size = msg_len;
#ifdef DEBUG
dump_mem("encoded buffer", buffer_addr, *buffer_size);
#endif
return !err ? msg_count : err;
I tested these fixes out on the P2020 and it worked like a charm. I have not tested them on anything else although I really just used the same methodology used throughout that code so it *should* work on other systems.
