Hello Austin,
great job! Our developers will have a look on your patch and implement it in the driver asap.
PCAN-USB FD Linux Driver Issues on Yocto Linux PowerPC
- S.Grosjean
Re: PCAN-USB FD Linux Driver Issues on Yocto Linux PowerPC
Hi Austin,
Back from my holidays, I'd first like to thank you a lot for all of your hard and detailed work!
We will obviously include the proposed patch that actually seems to fix the endian issue for all of our USB to CAN-FD interfaces. We will next do a whole check of the entire code, to track any other pending u16, and should quickly do a 8.5-beta accordingly.
Many thanks again,
Stéphane
Many thanks again,
Stéphane
- S.Grosjean
Hi Austin,
We have included your change in a 8.4.1 beta version. As you'll see, it's a bit different than yours, since the HW_SRR flag should be handled in all cases. As you expected, the code works over little endian archs. Anyway, if you're always able to run pcan over your PPC arch, it would be nice if you could install then run this new one (see attachment).
Your feedback will be welcome!
Thanks again and kind regards,
Stéphane
Stéphane
- peak-linux-driver-8.4.1-beta-20170809.tar.gz
- next-8.4.1-RC1
- (968.9 KiB) Downloaded 520 times
Hi Stéphane,
I installed the beta version and can confirm it works perfectly for both transmit and receive on my PPC.
I'd say with that driver we can close this topic.
Thanks!
-Austin
Thanks!
-Austin
