Preferred Hex conversion in C#
Is there a preferred hex conversion for can data? In c# I'm using Convert.ToInt32(fields[0], 16). Is this correct? Any help would be greatly appreciated.
Re: Preferred Hex conversion in C#
yes. It is OK. Check the PCAN-Basic samples. In there you will find a lot of code in C# (and other languages). For instance:
// We configurate the Message. The ID,
// Length of the Data, Message Type
// and the data
CANMsg.ID = Convert.ToUInt32(txtID.Text, 16);
Perfect, thanks!
