VBScript: CAN signals with the same name
User41
Post by User41 » Mon 18. Sep 2017, 14:36
Hello.
I'm writing a very siple VBScript that given the value of a CAN signal copies this value into another signal.
Normally, whit two signals with different names I do as follows:
Sub Example()
dim sig1, sig2
set sig1=Signals("VAR1")
set sig2=Signals("VAR2")
While true
          sig1.Value = sig2.Value
          wait 10
Wend
End Sub
VAR1 and VAR2 are defined in the .sym file.
Now I'm facing the problem that the 2 variables have the same name, what differs is the multiplexer. Below there is an example of the symbol file:
FormatVersion=5.0 // Do not edit this line!
Title="EXAMPLE"
{SENDRECEIVE}
[MESSAGE]
ID=001h
DLC=8
Mux=MUL1 0,2 1
Var=Var1 unsigned 8,8
[MESSAGE]
DLC=8
Mux=MUL2 0,2 2
I cannot simply use the Signals collection anymore. How can I use the multiplexer too? I've tried this:
set sig1=Multiplexer("MUL1").Signals("VAR1")
but this does not work.
Can someone gime me a hint on how to solve this?
Thanks.
K.Wolf
Re: VBScript: CAN signals with the same name
Post by K.Wolf » Tue 19. Sep 2017, 09:53
You can use the qualified name of the signal to find the correct signal in the collection:
Set sig = Signals("MESSAGE.MUL1.Var1")
and
Set sig = Signals("MESSAGE.MUL2.Var1")
User41
Post by User41 » Wed 20. Sep 2017, 12:01
It was, actually, very easy.
Thanks for the quick answer K.Wolf.
