[root@AEP peak-linux-driver-8.4.0]# make
make[1]: Entering directory `/root/Desktop/peak-linux-driver-8.4.0/driver'
make[1]: Nothing to be done for `depend'.
make[1]: Leaving directory `/root/Desktop/peak-linux-driver-8.4.0/driver'
*** Host machine kernel version=2.6.32-696.10.1.el6.x86_64
*** Driver kernel version=2.6.32-696.10.1.el6.x86_64 (2.6.32)
*** Path to kernel sources=/lib/modules/2.6.32-696.10.1.el6.x86_64/build
*** use KBUILD=yes
*** cc version=4.4.7
make -C /lib/modules/2.6.32-696.10.1.el6.x86_64/build SUBDIRS=/root/Desktop/peak-linux-driver-8.4.0/driver EXTRA_CFLAGS="-I/root/Desktop/peak-linux-driver-8.4.0/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNO_NETDEV_SUPPORT -DNO_RT " V=0 modules
make[2]: Entering directory `/usr/src/kernels/2.6.32-696.10.1.el6.x86_64'
CC [M] /root/Desktop/peak-linux-driver-8.4.0/driver/src/pcan_main.o
CC [M] /root/Desktop/peak-linux-driver-8.4.0/driver/src/pcan_fops.o
In file included from /root/Desktop/peak-linux-driver-8.4.0/driver/src/pcan_fops.c:558:
/root/Desktop/peak-linux-driver-8.4.0/driver/src/pcan_fops_linux.c:903: error: field ‘timestamp’ has incomplete type
/root/Desktop/peak-linux-driver-8.4.0/driver/src/pcan_fops_linux.c:915: error: field ‘tv_init’ has incomplete type
/root/Desktop/peak-linux-driver-8.4.0/driver/src/pcan_fops_linux.c:917: error: expected specifier-qualifier-list before ‘compat_int_t’
/root/Desktop/peak-linux-driver-8.4.0/driver/src/pcan_fops_linux.c: In function ‘pcan_compat_ioctl’:
/root/Desktop/peak-linux-driver-8.4.0/driver/src/pcan_fops_linux.c:1200: error: implicit declaration of function ‘compat_ptr’
/root/Desktop/peak-linux-driver-8.4.0/driver/src/pcan_fops_linux.c:1200: warning: initialization makes pointer from integer without a cast
/root/Desktop/peak-linux-driver-8.4.0/driver/src/pcan_fops_linux.c:1229: error: ‘struct pcanfd_state32’ has no member named ‘bus_state’
/root/Desktop/peak-linux-driver-8.4.0/driver/src/pcan_fops_linux.c:1232: error: ‘struct pcanfd_state32’ has no member named ‘bus_state’
/root/Desktop/peak-linux-driver-8.4.0/driver/src/pcan_fops_linux.c:1357:2: warning: #warning "Compiling for __LP64__"
make[3]: *** [/root/Desktop/peak-linux-driver-8.4.0/driver/src/pcan_fops.o] Error 1
make[2]: *** [_module_/root/Desktop/peak-linux-driver-8.4.0/driver] Error 2
make[2]: Leaving directory `/usr/src/kernels/2.6.32-696.10.1.el6.x86_64'
make[1]: *** [all] Error 2
make[1]: Entering directory `/root/Desktop/peak-linux-driver-8.4.0/lib'
cc -o libpcan.so.0.6 -DNO_RT -I. -I../driver -fPIC -shared -Wall src/libpcan.c -Wl,-soname,libpcan.so.0
ln -sf libpcan.so.0.6 libpcan.so
cc -o libpcanfd.so.0.1 -DNO_RT -I. -I../driver -fPIC -shared -Wall -DPCANFD_OLD_STYLE_API src/libpcanfd.c -Wl,-soname,libpcanfd.so.0
ln -sf libpcanfd.so.0.1 libpcanfd.so
make[1]: Leaving directory `/root/Desktop/peak-linux-driver-8.4.0/lib'
make[1]: Entering directory `/root/Desktop/peak-linux-driver-8.4.0/test'
cc -DNO_RT -g -I. -I../lib -I../driver src/receivetest.c src/common.c -lpcanfd -L../lib -o receivetest
cc -DNO_RT -g -I. -I../lib -I../driver src/transmitest.cpp src/common.c src/parser.cpp -lpcanfd -lstdc++ -L../lib -o transmitest
cc -DNO_RT -g -I. -I../lib -I../driver src/bitratetest.c src/common.c -lpcanfd -L../lib -o bitratetest
cc -DNO_RT -g -I. -I../lib -I../driver src/filtertest.cpp src/common.c -lpcanfd -lstdc++ -L../lib -o filtertest
cc -DNO_RT -g -I. -I../lib -I../driver src/pcan-settings.c -lpopt -L../lib -g -o pcan-settings
cc -DNO_RT -g -I. -I../lib -I../driver src/pcanfdtst.c -lpcanfd -L../lib -o pcanfdtst
make[1]: Leaving directory `/root/Desktop/peak-linux-driver-8.4.0/test'
