I'm trying to use CANTP_AddMapping function for target type functional.
According to my ECU specification :
CAN Broadcast id : 0x223
CAN tester id : 0x12B
First I wrote the following code :
TPUDSStatus resultMap = CANTP_AddMapping(PCANTP_USBBUS1, //CanChannel
0x223, //canID
CAN_ID_NO_MAPPING, //canIDResponse
PCANTP_ID_CAN_11BIT, // canIdType
PCANTP_FORMAT_NORMAL, //formatType
PCANTP_MESSAGE_DIAGNOSTIC, // msgType
PUDS_SERVER_ADDR_TEST_EQUIPMENT, //sourceAddr
0xF5, // targetAddr
PCANTP_ADDRESSING_FUNCTIONAL, //targetType
0x00 // remoteAddr
0x12B, //canID
0xF5, //sourceAddr
PUDS_SERVER_ADDR_TEST_EQUIPMENT, // targetAddr
PCANTP_ADDRESSING_PHYSICAL, //targetType
0x00 // remoteAddr
I got the following CAN communication
; Message Number
; | Time Offset (ms)
; | | Type
; | | | ID (hex)
; | | | | Data Length
; | | | | | Data Bytes (hex) ...
1) 1403.4 Rx 0111 8 00 00 00 5D 6E 00 00 00 //not relevant
2) 1949.4 Rx 00000123 8 00 00 00 00 00 00 00 00 //not relevant
3) 2177.4 Rx 0223 8 03 22 FD 02 FF FF FF FF
4) 2179.5 Rx 012B 8 07 62 FD 02 00 00 02 22
5) 3950.4 Rx 00000123 8 00 00 00 00 00 00 00 00 //not relevant
6) 5951.3 Rx 00000123 8 00 00 00 00 00 00 00 00 //not relevant
7) 6404.2 Rx 0111 8 00 00 00 5D 6E 00 00 00 //not relevant
But, my second mapping is wrong because I can get the answer from the ECU
After some modification, the best I can catch is the request from the tester itself
"UDS REQUEST from 0xF1 (to 0xF5, with RA 0x0) - result: 0 - OK !\n"
" -> Length: 3, Data= 22 FD 02"
Could you explain me how to fix this?
Thank you in advance.
Best regards
Alexis
