I tried to plug two PCAN-USB X6 in one host (Ubuntu 16.04 LTS with Peak/PCAN driver, i.e. not the Linux SocketCAN kernel driver).
For the first X6, all ports work just fine having device names pcan32...pcan37 mapped to can0...can5. For the second, the first two ports seem to work fine (having device names pcan38 and pcan39 mapped to can6 and can7), but then the driver reports the following:
[1182841.521888] pcan: not enough minors
[1182841.521894] pcan: failed to register PCAN-USB X6 CAN1 as a new USB CAN channel err -19
[1182841.329762] pcan: PCAN-USB X6 (01h PCB03h) fw v2.2.3 bl v1.0.2
[1182841.330054] pcan: PCAN-USB X6 channel 1 device number=0
[1182841.330424] pcan: registered CAN-FD netdevice can6 for usbfd hw (238,38)
[1182841.330426] pcan: usb device minor 38 found
[1182841.330680] pcan: PCAN-USB X6 channel 2 device number=0
[1182841.331019] pcan: registered CAN-FD netdevice can7 for usbfd hw (238,39)
[1182841.331020] pcan: usb device minor 39 found
[1182841.710073] pcan: not enough minors
[1182841.710077] pcan: failed to register PCAN-USB X6 CAN1 as a new USB CAN channel err -19
*------------- Release_20171027_n (8.5.1) Jan 3 2018 15:46:05 --------------
*--------------------- 8 interfaces @ major 238 found -----------------------
32 usbfd can0 90 000 0x001c 06a06acd 0000000e 01733d66 00000000 0x0000
33 usbfd can1 90 000 0x001c 0a5e6ab7 00000010 023b0e07 00000000 0x0000
34 usbfd can2 90 000 0x001c 00000000 00000000 00000000 00000000 0x0000
35 usbfd can3 90 000 0x001c 00000000 00000000 00000000 00000000 0x0000
36 usbfd can4 90 000 0x001c 0596b462 0000000e 0141713b 00000000 0x0000
37 usbfd can5 90 000 0x001c 0ee0f37c 00000008 033043ce 00000000 0x0000
38 usbfd can6 91 000 0x001c 00000000 00000000 00000000 00000000 0x0000
39 usbfd can7 91 000 0x001c 00000000 00000000 00000000 00000000 0x0000
I know that there are fixed device minor number ranges for each category (cf. p.13 of the manual), but as we do not have any PC-CARD devices, using those minor numbers (40...47) or those starting at 48 would work both for me.
Thank you already,
Jan
