Listen mode
lukas
Re: Listen mode
Post by lukas » Mon 22. Jan 2018, 07:58
It looks like that module is working in normal operation mode (pcan_pcan.png)
Also tried to reload configuration with changed can speed for one channel to check if I am reloading confiugration correctly. CAN speed was changed but I am still in normal operation mode and not listen operation mode
Re: Listen mode
Post by G.Lang » Mon 22. Jan 2018, 11:37
Hm..curios :?
please post a screenshot with the used version and PPCAN version information
Furthermore press the right mouse button and read the current configuration from the module, save the config and post it also.
lukas
Re: Listen mode
Post by lukas » Mon 22. Jan 2018, 16:00
In attachment
read_from_device_0.ppproj
(17.27 KiB) Downloaded 625 times
Re: Listen mode
Post by G.Lang » Tue 23. Jan 2018, 13:29
Hi Lukas,
we are able to reproduce your problem, it´s an issue of the used transceiver module in combination with the used firmware which could happen under some circumstances :o
Please contact us per email and we send you a new firmware + necessary tools/instructions for the update process.
best regards
