transmitest und receivetest not working
KatharinaB
Post by KatharinaB » Sat 27. Jan 2018, 14:40
I am using the PCAN-PCI Single Channel (IPEH-002064) with the library v8.5.1
./lspcan -T -t -i shows:
dev name	port	irq	clock	btrs	bus
[PCAN-PCI Express 0]
 |_ pcanpci0	CAN1	16	8MHz	1M	CLOSED
dmesg | grep pcan shows
[ 1718.079499] pcan: Release_20171027_n (le)
[ 1718.079500] pcan: driver config [mod] [isa] [pci] [pec] [dng] [par] [pcc]
[ 1718.084587] pcan: pci device minor 0 found
[ 1718.084685] pcan: major 237.
[ 3816.932785] pcan: __pcan_ioctl(cmd=21505): unsupported cmd (dir=0 type=84 nr=1 size=0)
[ 4704.014557] pcan: bitrate error 0.0%
[ 4704.014584] pcan: bitrate error 0.0%
[ 4704.014599] pcan: bitrate error 0.0%
[ 4704.014623] pcan: bitrate error 0.0%
[ 4704.014640] pcan: bitrate error 0.0%
[ 4704.014665] pcan: bitrate error 0.0%
[ 4704.014679] pcan: bitrate error 0.0%
[ 4704.014701] pcan: bitrate error 0.0%
[ 4704.014714] pcan: bitrate error 0.0%
[ 4704.014739] pcan: bitrate error 0.0%
[ 4704.014753] pcan: bitrate error 0.0%
[ 4704.014774] pcan: bitrate error 0.0%
[ 4704.014787] pcan: bitrate error 0.0%
[ 4704.014810] pcan: bitrate error 0.0%
[ 4704.014824] pcan: bitrate error 0.0%
[ 4704.014848] pcan: bitrate error 0.0%
[ 4704.014860] pcan: bitrate error 0.0%
[ 4704.014883] pcan: bitrate error 0.1%
[ 4704.014894] pcan: bitrate error 0.1%
[ 4704.014919] pcan: bitrate error 0.2%
ls -l /dev/pcan* shows
crw-rw-rw- 1 root root 237,  0 Jan 27 11:45 /dev/pcan0
crw-rw-rw- 1 root root 237, 16 Jan 27 11:45 /dev/pcan16
crw-rw-rw- 1 root root 237, 24 Jan 27 11:45 /dev/pcan24
crw-rw-rw- 1 root root 237, 32 Jan 27 11:45 /dev/pcan32
crw-rw-rw- 1 root root 237, 40 Jan 27 11:45 /dev/pcan40
crw-rw-rw- 1 root root 237,  8 Jan 27 11:45 /dev/pcan8
crw-rw-rw- 1 root root 237,  0 Jan 27 11:40 /dev/pcanpci0
/dev/pcan-pci:
total 0
drwxr-xr-x 2 root root 60 Jan 27 11:40 0
cat /proc/pcan shows
*------------- Release_20171027_n (8.5.1) Jan 27 2018 11:37:35 --------------
*---------------- [mod] [isa] [pci] [pec] [dng] [par] [pcc] -----------------
*--------------------- 1 interfaces @ major 237 found -----------------------
 0    pci   -NA- df200000 016 0x0014 00000001 00000000 00000000 00000000 0x0000
and my kernel is 4.13.0-32-generic and it is also up-to-date
I connected a device (with 120Ohm) to the can interface thats sends messages with a bitrate of 1Mbit/s
Unfortunately the receive and send tests do not seem to work:
./receivetest -f=/dev/pcan0 -b=0x0014 -e shows:
receivetest Version "Release_20150611_n"  (http://www.peak-system.com)
------- Copyright (C) 2004-2009 PEAK System-Technik GmbH ------
receivetest comes with ABSOLUTELY NO WARRANTY.     This is free
software  and you are welcome  to redistribute it under certain
conditions.   For   details   see    attached   COPYING   file.
receivetest: device node="/dev/pcanpci0"
             Extended frames are accepted, init with BTR0BTR1=0x0014
receivetest: driver version = Release_20171027_n
936727944.635 receivetest: m s 0x00000001 4 00 00 00 00
receivetest: pending CAN status 0x0020 read.
and once I terminate is adds
^Creceivetest: type            = pci
             io              = 0xdf200000
             irq             = 16
             count of reads  = 1
             count of writes = 0
             count of errors = 0
             count of irqs   = 0
             last CAN status = 0x0020
             last error      = 0
             open paths      = 1
receivetest: finished (0): 1 message(s) received
Same with
./transmitest hello.txt -f=/dev/pcanpci0 -b=0x0014 : first
transmitest Version "Release_20150610_n"  (http://www.peak-system.com)
transmitest comes with ABSOLUTELY NO WARRANTY.     This is free
transmitest: device node="/dev/pcanpci0"
             Only standard frames are sent, init with BTR0BTR1=0x0014
             Data will be read from "hello.txt".
transmitest: driver version = Release_20171027_n
and after terminating:
^Ctransmitest: type            = pci
             io              = 0xdf200000
             irq             = 16
             count of reads  = 2
             count of writes = 501
             count of errors = 1
             count of irqs   = 0
             last CAN status = 0x0081
             last error      = 0
             open paths      = 1
transmitest: finished (0).
Also it always shows 501 counts of writes
I hope you can help me.
Reason: Inserted [code] tags for improved readability
S.Grosjean
Re: transmitest und receivetest not working
Post by S.Grosjean » Mon 29. Jan 2018, 11:27
cmd=21505 is absolutely unknown. If this cmd comes from receivetest, so it looks like there's a problem between user and kernel spaces.
Could you please give us the result of:
$ uname -a
and, also, the output of the command that built everything in the driver, that is:
$ cd peak-linux-driver-8.5.1
$ make clean
$ make
$ sudo make install
Thanks.
KatharinaB
Post by KatharinaB » Mon 29. Jan 2018, 12:00
uname -a returns:
Linux as-desktop 4.13.0-32-generic #35~16.04.1-Ubuntu SMP Thu Jan 25 10:13:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
and the build:
make
make[1]: Entering directory '/home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver'
make[1]: Nothing to be done for 'depend'.
make[1]: Leaving directory '/home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver'
*** Host machine kernel version=4.13.0-32-generic
*** Driver kernel version=4.13.0-32-generic (4.13.0)
*** Path to kernel sources=/usr/src/linux-headers-4.13.0-32-generic
*** use KBUILD=yes
*** cc version=5.4.0
make -C /usr/src/linux-headers-4.13.0-32-generic  SUBDIRS=/home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver        EXTRA_CFLAGS="-I/home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver        -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNO_NETDEV_SUPPORT	 -DNO_RT  -Wno-date-time" V=0 modules
make[2]: Entering directory '/usr/src/linux-headers-4.13.0-32-generic'
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_main.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_fops.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_fifo.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_filter.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_parse.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_sja1000.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_common.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_timing.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcanfd_core.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcanfd_ucan.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_pci.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcanfd_pci.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_pciec.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_isa.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_dongle.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_pccard_core.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_pccard.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_usb_core.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_usb.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcan_usbpro.o
  CC [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/src/pcanfd_usb.o
  LD [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/pcan.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/pcan.mod.o
  LD [M]  /home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/driver/pcan.ko
make[2]: Leaving directory '/usr/src/linux-headers-4.13.0-32-generic'
make[1]: Entering directory '/home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/lib'
cc -DNO_RT -I. -I../driver -fPIC -Wall -Wcast-align -Wredundant-decls  -DPCANFD_OLD_STYLE_API -c src/libpcan.c -o obj/libpcan.o
cc -shared -Wl,-soname,libpcan.so.0 -o lib/libpcan.so.0.6 obj/libpcan.o
cd lib/; ln -sf libpcan.so.0.6 libpcan.so
cc -DNO_RT -I. -I../driver -fPIC -Wall -Wcast-align -Wredundant-decls  -DPCANFD_OLD_STYLE_API -c src/libpcanfd.c -o obj/libpcanfd.o
cc -shared -Wl,-soname,libpcanfd.so.0 -o lib/libpcanfd.so.0.1 obj/libpcanfd.o
cd lib/; ln -sf libpcanfd.so.0.1 libpcanfd.so
ar rcs lib/libpcanfd.a obj/libpcanfd.o
Info: only 64-bit version of libpcan can be built. 32-bit version of libpcan can't because the 32-bit version of libc seems not being installed...
make[1]: Leaving directory '/home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/lib'
make[1]: Entering directory '/home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/test'
cc -DNO_RT -g -I. -I../lib -I../driver    src/receivetest.c src/common.c -lpcanfd  -L../lib/lib   -o receivetest
cc -DNO_RT -g -I. -I../lib -I../driver    src/transmitest.cpp src/common.c src/parser.cpp -lpcanfd -lstdc++  -L../lib/lib   -o transmitest
cc -DNO_RT -g -I. -I../lib -I../driver    src/bitratetest.c src/common.c -lpcanfd  -L../lib/lib   -o bitratetest
cc -DNO_RT -g -I. -I../lib -I../driver    src/filtertest.cpp src/common.c -lpcanfd -lstdc++  -L../lib/lib   -o filtertest
cc -DNO_RT -g -I. -I../lib -I../driver    src/pcanfdtst.c -lpcanfd  -L../lib/lib   -o pcanfdtst
cc -DNO_RT -g -I. -I../lib -I../driver    src/pcan-settings.c -lpopt  -L../lib/lib   -g -o pcan-settings
make[1]: Leaving directory '/home/as/Devel/KIT18d/can_ws/src/libpcan/peak-linux-driver-8.5.1/test'
sudo make install
Info: /lib/modules/4.13.0-32-generic/misc exists.
Info: Left current 'pcan'-entry in /etc/modprobe.d/pcan.conf untouched.
Info: Copied 45-pcan.rules to /etc/udev/rules.d.
Info: mainline drivers removed and blacklisted in
      /etc/modprobe.d/blacklist-peak.conf
mkdir -p /usr/lib
cp -d lib/* /usr/lib
if [ -d lib32 ]; then \
	mkdir -p /usr/lib32; \
	cp -d lib32/* /usr/lib32; \
fi
mkdir -p /usr/include
chmod 644 libpcan.h libpcanfd.h
cp libpcan.h libpcanfd.h /usr/include
/sbin/ldconfig
/sbin/ldconfig.real: /usr/local/cuda-8.0/targets/x86_64-linux/lib/libcudnn.so.7 is not a symbolic link
/sbin/ldconfig.real: /usr/local/cuda-8.0/targets/x86_64-linux/lib/libcudnn.so.5 is not a symbolic link
cp receivetest transmitest bitratetest filtertest pcanfdtst pcan-settings /usr/local/bin
S.Grosjean
Post by S.Grosjean » Mon 29. Jan 2018, 12:18
Ok. So everything seems ok (except you're running an old gcc).
Now, load the new driver:
$ sudo rmmod pcan
$ sudo modprobe pcan
Then, give us the output of:
$ dmesg | grep pcan
Next, launch the receive application
$ receivetest -f=/dev/pcan0 -b=0x0014 -e
Finally, open another shell window and while receivetest is running, give us (again) the output of:
$ dmesg | grep pcan
KatharinaB
Post by KatharinaB » Mon 29. Jan 2018, 12:58
The first output after loading the driver is:
dmesg | grep pcan
[    2.169199] pcan: Release_20171027_n (le)
[    2.169200] pcan: driver config [mod] [isa] [pci] [pec] [dng] [par] [pcc]
[    2.169224] pcan 0000:04:00.0: enabling device (0000 -> 0002)
[    2.176057] pcan: pci device minor 0 found
[    2.176431] pcan: major 238.
[ 9395.956260] pcan: removed.
[ 9411.349037] pcan: Release_20171027_n (le)
[ 9411.349038] pcan: driver config [mod] [isa] [pci] [pec] [dng] [par] [usb] [pcc]
[ 9411.354151] pcan: pci device minor 0 found
[ 9411.354202] usbcore: registered new interface driver pcan
[ 9411.354273] pcan: major 238.
and while running the receivetest it is still the same:
thanks for your help
S.Grosjean
Post by S.Grosjean » Mon 29. Jan 2018, 13:07
Ok. Up to now, everything is ok.
What does say the running receivetest? If your /dev/pcan0 is connected to your CAN bus, you should see something...
FYI, instead of receivetest, you could use the (new) pcanfdtst tool which gives more info from the CAN bus. Try:
$ pcanfdtst rx -b 1M /dev/pcan0
KatharinaB
Post by KatharinaB » Mon 29. Jan 2018, 13:51
if I try pcanfdtst rx -b 1M /dev/pcan0
it returns
1517229872~691085 /dev/pcan0  > BUS STATE=ACTIVE   [Rx:0 Tx:0]
and after I terminate it:
/dev/pcan0 > [packets=0 calls=1 bytes=0 seq_err=0]
received frames: 0
the reveivetest retuns:
receivetest: device node="/dev/pcan0"
1106474675.928 receivetest: m s 0x00000001 4 00 00 00 00
             io              = 0xdf200000
             irq             = 16
             count of reads  = 1
             count of writes = 0
             count of errors = 0
             count of irqs   = 0
             last error      = 0
             open paths      = 1
I also tried a different CAN device but it still shows the same result
Katharina
S.Grosjean
Post by S.Grosjean » Mon 29. Jan 2018, 14:23
Well everything is ok for us. Status=0x0020 says nothing has been received by the driver from the CAN bus.
Can you check whether some frames are present on the CAN bus?
Stéphane
KatharinaB
Post by KatharinaB » Mon 29. Jan 2018, 15:54
I have checked both devices with a can-to-usb adapter and a can-monitoring-program on a different computer and they were both sending messages. Are there maybe some basic settings I need to change on the computer
thanks for the help.
Katharina
S.Grosjean
Post by S.Grosjean » Tue 30. Jan 2018, 09:31
When there's traffic on the CAN bus, type:
Then, from another shell window:
$ cat /proc/pcan > /tmp/pcan_1
Then:
$ pcanfdtst tx -b 1M -i 0x123 -n 100 -l 8 /dev/pcan0 > /tmp/pcanfdtst_tx_100
Then redo:
$ cat /proc/pcan > /tmp/pcan_2
Finally, send us /tmp/pcan_1, /tmp/pcanfdtst_tx_100 and /tmp/pcan_2" (or copy-paste then) please.
Thanks and regards,
Stéphane
