PCANBasic: Read event problem with PCAN USB + PCI
A.Kapp
Post by A.Kapp » Thu 1. Mar 2012, 14:01
I use PCANBasic with Python 2.6 on a Windows 7 machine (Windows 7 Ultimate, 64 bit).
PCANBasic.dll, dating 20.01.2012
PCAN-View, version 3.1.5.200
Before yesterday I only used PCAN USB-adapter and managed to set up a Read event which reliably triggered when a message was in the message queue.
Yesterday I installed a PCI express card.
Adapting the code I managed to set up a Read event for the PCI channel.
However, after having installed the PCI card and resetting the code, the Read event of the PCAN USB adapter gets triggered before a message is in the message queue (checked with PCAN-View).
Error message: "Bus error: an error counter reached the 'heavy' limit" (code 8)
Is there some "hidden" linkage between the different CAN channels?
There is no traffic on the other CAN channels.
Andreas
Re: PCANBasic: Read event problem with PCAN USB + PCI
Post by K.Wagner » Thu 1. Mar 2012, 14:54
Dear,
A.Kapp wrote:Error message: "Bus error: an error counter reached the 'heavy' limit" (code 8)
The error you see is a BUSHEAVY error. It seems to be a problem within the CAN network, for example the use of different baudrates at a time. Please take a look to this post
A.Kapp wrote: Is there some "hidden" linkage between the different CAN channels?
There is any hidden linkage between two channels of a PCI-Express card; they are completly independient. The link between both channels exists when they are connected to the same CAN-Network.
A.Kapp wrote:However, after having installed the PCI card and resetting the code, the Read event of the PCAN USB adapter gets triggered before a message is in the message queue (checked with PCAN-View).
Some additional information about the topology of your connection is necessary in order to help you:
  • * Are your cables terminated?
    * How many CAN applications do you start at the same time (including your application)?
    * How many hardware/channels are you connecting at a time?
    * Which baurate do you use within all applications?
    * Is there a communication between two pcan-views (one connected to each hardware/channel) possible?
A.Kapp
Post by A.Kapp » Fri 2. Mar 2012, 08:45
Hello Kenneth,
I try to answer your list of questions.
Here are my answers:
  • * I have a one-to-one connection between the PCAN-USB adapter and a microcontroller.
    * The cables are terminated.
    * The baudrate is set to 500kbit/sec.
    * One instance of PCAN-View and only one self-written application (32bit Python 2.6 on Windows7, 64bit) is running (since I am using PCANBasic more applications are not possible).
    * Reading and writing are possible.
    * Every now and then a Read event is triggered even though there is no message in the queue. The corresponding error is code 0x8 (Bus heavy).
    * When using the same physical network together with a PCI 4channel card there is no problem at all, i.e. Read events are only triggered when messages are in the queue.
Why do you think that re-initializing might be a solution when reading and writing are working alright?
I hope that I have provided the necessary information this time.
Thank you very much for your help.
Kind regards,
Andreas
Post by G.Lang » Fri 2. Mar 2012, 10:55
which driver version from the "pcan_usb.sys" do you use? If not version 3.8.2.10146 then please download the current version from the following link: http://www.peak-system.com/cupd2/PeakOemDrv.zip
What´s the firmware version from the PCAN-USB adaptor?
A.Kapp
Post by A.Kapp » Fri 2. Mar 2012, 13:30
I have to admit that I had not updated the driver lately.
But even now having updated the driver I still have this strange behaviour:
Read event triggered, no message in the queue. Error: Bus heavy.
This holds even when no hardware is connected to the USB adaptor.
  • * PCAN-Channel-Version: PCAN_USB 3.8.2.10146
    * PCAN-API-Version: 1, 2, 1, 31
    * Firmware: 2.8
Andreas
Post by PEAK-Support » Fri 2. Mar 2012, 21:25
Dear,
if you get a BUSHEAVY please first check this:
http://www.peak-system.com/forum/viewto ... f=120&t=39
Looks like you have a physical problem on your bus. Is the bus terminated?, are two active nodes on the bus?, are they use the same Baudrate? (incl. same sample point)
