I have an USB PCAN Adpater running on Ubuntu. I installed the driver and pcanbasic and it seems to be working (candump shows messages sent by another PC via PCAN View) and I can send messages in my Java program.
My problem is that I can't receive messages in Java, even with the example Application in pcanbasic. Sending is not a problem.
Could someone point me in the right direction, I don't know what could cause this problem.
Thanks in advance.
Can Not Recieve Can Msg With Example Java Code
- Software Development
Re: Can Not Recieve Can Msg With Example Java Code
Hello Ethelena,
By default in the Java sample and after you connect to a device, the working channel is in a paused state. You need to click on the "Start" button (under the "Connected Channels" groupbox) in order to start receiving messages.
- pcanjni_sample.PNG (47.36 KiB) Viewed 2753 times
Fabrice
Fabrice
