PCAN-MicroMod Config not finding device
Universal I/O Module with CAN Interface
eldonz
Post by eldonz » Mon 16. Apr 2018, 01:10
I have a MicroMod Digital 2 and an Analog 2 module. When I hook up the CAN bus from the PCAN USB adapter to a module, I can see the module transmitting data. I tell the Configuration software to find the modules on the bus and it fails. I can see the message going out on the bus @ 0x7E7. If I duplicate the 0x7E7 message, by using the PCAN View software, the module will respond and the Configuration software will see two modules instead of one. I can then select the module and tell the software to read the modules configuration. I can see the bus traffic via the trace mode of the PCAN View software. After reading the configuration, I will get an error that the configuration was not read successfully. The CAN bus has termination resistors at both ends; the PCAN USB adapter at one end and the module at the other end. Both the Digital and Analog modules fail/perform the same way.
Any ideas or suggestions?
Eldon
Re: PCAN-MicroMod Config not finding device
Post by M.Maidhof » Mon 16. Apr 2018, 12:23
if you connect several PCAN-MicroMod modules on the same CAN bus system, you have to set different module numbers (soldering jumpers) on the modules, otherwise they will respond with the same IDs, which will cause the effect you have seen. As a workaround, simply connect only one MicroMod on your CAN bus for configuration. See MicroMod manual on page 7 for more details.
eldonz
Post by eldonz » Mon 16. Apr 2018, 14:33
Micheal,
Thanks for the response but I only have one module on the bus at a time. As stated, the problem is when the configuration software polls the bus, the module does not respond. If I send the polling command via PCAN View, the module will respond.
Later,
Eldon
Post by M.Maidhof » Mon 16. Apr 2018, 15:44
which version of the MicroMod Configuration Tool do you use? Did you change any timeout settings in the options?
eldonz
Post by eldonz » Mon 16. Apr 2018, 16:02
Michael,
The version on MicroMod Config is 2.5.7.63. I have not changed any settings. One other thing to note is under the Options-Hardware Tab, the PCAN USB device shows up twice but only the first one works.
The "Read Configuration" sends out the 0x7E7 command but the module never replies. If I send out the 0x7E7 command while the "Read Configuration" is waiting for a response, the module will reply.
Later,
Eldon
Post by M.Maidhof » Tue 17. Apr 2018, 09:45
which driver version do you use for PCAN-USB? When using Windows 7, please check for the latest USB chipset drivers when using USB3. There are known issues with older USB3 chipset drivers.
eldonz
Post by eldonz » Tue 17. Apr 2018, 15:19
Michael,
The PCAN-USB driver is V4.1.2.16115. The OS is windows 7 x64. Also, the PCAN-USB is plugged in to a USB2 port and not a USB3 port.
Later,
Eldon
Post by M.Maidhof » Wed 18. Apr 2018, 09:55
please send an email to our support email address with reference to this forum post, we will send you a tool (Sysinfo) which scans your PC for all available PEAK drivers and dlls. This could be helpfull to find that problem on your system.
Just to be sure it is not a problem with your physical CAN setup, can you please test on an other PC?
eldonz
Post by eldonz » Wed 18. Apr 2018, 15:43
Michael,
The CAN bus setup works just fine because I can use the PCAN View software to monitor and write to the bus. I was able to watch the module and verify that the inputs to the module were changing. I was also able to change the status of an output on the module. When I plugged in the Analog module, I was able to see it updating at 40 Hz and sending over the analog input values.
I will submit an email to your support and proceed from there.
Thanks for the help,
Eldon
Post by M.Maidhof » Wed 18. Apr 2018, 15:56
please also install MicroMod Config Tool on a different PC, to see if it is a PC based problem only.
best regards
