Getting back value to transmit
geralde.givens
Post by geralde.givens » Wed 18. Apr 2018, 22:21
Hello to all,
I would like to make a VBscript to configure a device automatically. I succeed in transmitting few times the same frame with different value with standard macro. Now I would like to read bytes in a reception frame and put it in an emission frame. I think that is not possible with the standard macro, but it is in VBscript.
The problem is that I’m completely novice in writing VBscipt.
Below, you will find an example of the wanted function
Send 1 300h 12h 00h 00h 00h 00h 00h 00h 00h
Send 1 300h 43h 00h 00h 00h 00h 00h 00h 00h
Then I will received:
Received 1 400h 8F 01h 02h 03h 04h
Send 1 300h 13h 21h 10h 00h 00h 00h 00h 00h
Send 1 300h 21h 01h 02h 03h 04h
Send 1 300h 22h 01h 02h 03h 04h
If someone can give me the trick to do that, it would be very helpful.
Thanks a lot in advance
Re: Getting back value to transmit
Post by M.Maidhof » Thu 19. Apr 2018, 10:01
please have a look on the sample macros WaitForID100() and SendMessage() which will be available in your PCAN-Explorer 5 macro list. Simply merge those two macro files together, to have an suitable VBmacro for your application.
best regards
