I have a atom based device running WES. NXP SJA1000 CAN device on ISA bus. I installed pcan_isa driver (V 2.49.14-4542) and pcan view.
CAN IRQ =5
CAN I/O = 0x340
Problem 1: Can only send one message from pcan view without reseting.
Problem 2: Can't receive any messages. After 4 or 5 messages pcan view overruns stat counting up until reset.
When I use a Linux based compact flash in the device the CAN works with out problems.
pcan_isa driver problem with WES
Re: pcan_isa driver problem with WES
which CAN Hardware from PEAK do you use on your system?
This is our design. I have found the solution. It was a BIOS setting for the IRQ assignment.
please take care, its not allowed to use our pcan_isa.sys Windows driver or tools with an own design, its possible to purchase a licence from us, but what you are doing at the moment is illegal and could cause some problems for you! Please don't mix up Linux and Windows systems regarding the licence policy of such a driver system.
Thank you for the information. This is a test unit in the lab. We are evaluating the windows option. My task is to document what is required to install this driver including the licensing options. Please send me the licensing information for my documentation.
the forum is for support questions only, please contact us by email to send you details about the licence informations for the pcan-isa driver: info@peak-system.com
Please remove that driver again from your system, and don't document driver setups which are not legal. Thank you.
Driver is now removed from my system and the compact flash is reset back to original WES image. I will follow up about the licensing via email. Thank you for your help.
