Hi
I'm trying to send Select Calibration Data Page according to CCP Std 2.1 where Command Code = SELECT_CAL_PAGE 0x11;
using CCP_SelectCalibrationDataPage function available in PCCP.dll, unlucky the command code is 0x05, instead 0x11.
PCCP.dll is the last 32bit dll version dll available online on PEAK website.
Is any workaround to fix this issue?
Paolo
CCP_SelectCalibrationDataPage bug
Re: CCP_SelectCalibrationDataPage bug
yes, I can confirm this is a bug. Please contact our support (support[at]peak-system.com) referring to this post. We will then give you a test-Version with a fix.
Thanks for bringing this to our attention!
Thx for your quickly reply.
I sent u a mail as required.
Paolo
Paolo
New version is on the way. we will appreciate a feedback, that the problem was solved with this test version. We will release this version in the near future.
Thanks in advance
Thanks in advance
