err -110 submitting cmd *.* to PCAN-USB
USB to CAN Interface
JOJOTHEGREAT
Post by JOJOTHEGREAT » Tue 14. Aug 2018, 14:25
I am running peak-linux-driver-8.6.0 in a virtual machine on ubuntu 17.10.
- When typing the command
lspcan
I get the following: pcanusb32
pcanfdtst tx -n 10 - b 500k -p 1s /dev/pcan32
I get the following: failed to open "/dev/pcan32" (err -110) / No pcan device is opened ( same thing if I try with pcanusb32 )
- When trying to output
dmesg | grep pcan
I get a bunch of: err -110 submitting cmd 6.1 to PCAN-USB ( or cmd 4.1, 3.2, 11.2 or 9.2 )
Could anybody help me out with that?
Re: err -110 submitting cmd *.* to PCAN-USB
Post by M.Maidhof » Tue 14. Aug 2018, 15:43
please check that you have installed the VM guest extension pack. Next please post the output of cat /proc/pcan and uname -a
JOJOTHEGREAT
Post by JOJOTHEGREAT » Tue 14. Aug 2018, 18:01
Thanks for the quick response
cat /proc/pcan
*------------- Release_20180720_n (8.6.0) Aug 14 2018 16:38:55 --------------
*--------------------- 1 interfaces @ major 244 found -----------------------
32 usb -NA- 0 000 0x001c 00000000 00000000 00000000 00000000 0x0000
uname -a
Linux jojo-VirtualBox 4.13.0-46-generic #51-Ubuntu SMP Tue Jun 12 12:36:29 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
I should also have been saying that I am running my vm from OSX
Post by M.Maidhof » Wed 15. Aug 2018, 16:52
did you install the guest extension pack in your VM?
best regards
PS: please use a real Linux system to prevent such VM related problems.
JOJOTHEGREAT
Post by JOJOTHEGREAT » Wed 15. Aug 2018, 20:30
I have installed the extension pack indeed
Post by M.Maidhof » Thu 16. Aug 2018, 09:33
can you please check that cat /dev/pcan32 will work.
