EBADMSG error for new 8.6.0 peak driver
icegood
Post by icegood » Tue 25. Sep 2018, 10:36
Our code for J1939 device via can interface became broken after library update from 8.5.1 to 8.6.0.
In particular, procedure pcanfd_send_msg from driver code
was in 8.5.1:
	switch (pf->type) {
	case PCANFD_TYPE_CANFD_MSG:
		/* accept such messages for CAN-FD capable devices only */
		if ((dev->init_settings.flags & PCANFD_INIT_FD) &&
				(pf->data_len <= PCANFD_MAXDATALEN))
			break;
	case PCANFD_TYPE_CAN20_MSG:
		if (pf->data_len <= 8)
			break;
	default:
		pr_err(DEVICE_NAME
			": trying to send invalid msg (type=%xh len=%d)\n",
			pf->type, pf->data_len);
		return -EBADMSG;
now in 8.6.0:
switch (ptx->msg.type) {
				(ptx->msg.data_len <= PCANFD_MAXDATALEN))
			break;
		pr_err(DEVICE_NAME
			": trying to send invalid CAN FD msg (len=%d)\n",
			ptx->msg.data_len);
		return -EBADMSG;
		if (ptx->msg.data_len <= PCAN_MAXDATALEN)
			break;
	default:
		pr_err(DEVICE_NAME
			ptx->msg.type, ptx->msg.data_len);
		return -EBADMSG;
Before code for PCANFD_TYPE_CANFD_MSG type and missing PCANFD_INIT_FD in dev->init_settings.flags and len <= 8 worked well as it processed by 'case PCANFD_TYPE_CAN20_MSG'. Now it doesn't work anymore as it explicitly returned in 'case PCANFD_TYPE_CANFD_MSG'. how should we fix it? Should we have PCANFD_INIT_FD flag set all time?
S.Grosjean
Re: EBADMSG error for new 8.6.0 peak driver
Post by S.Grosjean » Tue 25. Sep 2018, 13:51
v8.5.1 was actually more permissive: you could send PCANFD_TYPE_CANFD_MSG even if you didn't use any CAN-FD adapter.
With 8.6.0, as far as you don't use CAN FD, your application should use PCANFD_TYPE_CAN20_MSG rather than PCANFD_TYPE_CANFD_MSG.
Using PCANFD_TYPE_CANFD_MSG could lead to set/clear internal CAN-FD options while the PC CAN interface had not been initialized for.
— Stéphane
