All-in-one USB Adapter for Communication through USB, CAN and RS-232
shinu
Post
by shinu » Wed 24. Oct 2018, 14:43
I am using PCAN-USB Hub to test a J1939 based keypad.
I have connected Can-H and Can-L wires to the correct pins on the USB interface.
With PCAN-View I am not able to receive any data on key press and status of the software is BUSHEAVY.
Do I need to change some settings to support J1939 ?
Any help would be much appreciated
Shinu
- Support
Post
by M.Maidhof » Wed 24. Oct 2018, 17:15
please set the baudrate to 250k and use a terminated CAN cable with termination resistors on both ends.
shinu
Post
by shinu » Thu 25. Oct 2018, 15:31
Hi Michael,
Thank you so much for the reply.
I already set the baudrate to 250K and connected 120ohm resistors on both the end.
Still not able to receive any data and status of the software is BUSHEAVY.
Shinu
- Support
Post
by M.Maidhof » Fri 26. Oct 2018, 10:22
please check that you wired CAN-H and CAN-L correctly. Please check which baudrate is used by your J1939 keypad.
Will the busheavy error directly occure after you switch on your keypad? Or only when you transmit a frame with PCAN-View?
shinu
Post
by shinu » Thu 8. Nov 2018, 18:02
Hi Michael,
Thank you.
It is working now.
Shinu
