Hi all,
I just colelcted some data using the Tracer.
In PCAN Explore 5 I was with two window:
1) Message Receive/Transmit with a Symbol file (working fine)
2) Tracer window was recording (below some part of the trace file)
;$FILEVERSION=1.3
;$STARTTIME=41038.4747755229
; E:\H-BUS Ac\H-BUS Drive Test 32%.trc
; Start time: 09/05/2012 11:23:40.605.1
; Bus Name Connection Protocol
; 4 VehicleCAN1 VehicleCAN@pcan_usb CAN
; Message Number
; | Time Offset (ms)
; | | Bus
; | | | Type
; | | | | ID (hex)
; | | | | | Reserved
; | | | | | | Data Length Code
; | | | | | | | Data Bytes (hex) ...
1) 1.477 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A4 7E 01
2) 131.495 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A5 7E 01
3) 261.532 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A8 7E 01
4) 391.566 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A7 7E 01
5) 521.583 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A6 7E 01
6) 651.645 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A8 7E 01
7) 781.641 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A5 7E 01
8) 911.661 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A5 7E 01
9) 1042.171 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A6 7E 01
10) 1171.614 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A7 7E 01
11) 1301.654 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A8 7E 01
12) 1432.072 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A8 7E 01
13) 1561.731 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A8 7E 01
14) 1691.753 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A8 7E 01
15) 1821.773 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A8 7E 01
16) 1954.295 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A7 7E 01
17) 2081.742 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A7 7E 01
18) 2211.762 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A6 7E 01
19) 2341.793 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A7 7E 01
20) 2471.852 4 Rx 18FF9F1E 00 8 C3 72 51 5F 50 A7 7E 01
Now I can't neither decode the trace file nor export data from the trace file.
I always get a "No simbol fond"
Con you help me?
Thank,
Trace File
Re: Trace File
please load and apply a symbol file or dbc file, to decode or export the trace data.
Re: Trace File
I already did it.
With the trace window active, I go to "MySymbol.sys" on the project window, do "apply" but still get the error.
The exact error is "No signal found". If I go to the connection property I see the correct sysmbol file. I use that sysmbol file when recording and the send/receive window was working properly.
Re: Trace File
please send trace file and symbol file to our support email address, to check that problem here with your files.
Please also send us the serialnumber of your PE5 licence in your email. It will also be helpfull to get an info which version of PCAN-Explorer 5 your are using at the moment.
BTW: your trace file uses bus 4, sure your connection and symbolfile is also using bus 4?
