Hi Sir:
I have few questions about PCAN Explorer 5, please help me.
1. What is the resolution of PCAN Explorer 5 ?
What I mean is that I use PCAN Explorer 5 to monitor CAN packages and there are several packages on CAN bus.
The interval of some CAN packages is 1 ms, does PCAN Explorer 5 can handle these message?
2.I found out that, the data will linear scale after zoom out, could I disable this function to see real data?
Thanks for your help!
Marcus
PCAN Explorer 5 question
Re: PCAN Explorer 5 question
here the answers to your questions:
1. PCAN-Explorer 5 offers a resolution of 100µs for receive messages and 1ms for transmit messages.
2. Sorry, but we don´t understand this. Please explain more detailed where you found that issue in PCAN-Explorer.
Hi Sir:
I really appreciate your reply, thanks!
About my question below, I will describe more detail.
I transmit my data every 1ms, after I stop logging data using plotter, I try to zoom in the picture.
In my logging data, some varibles are unsigned and some are signed, none of them is flaot.
However, when I zoom in several times, I founcd out taht, I saw float value on several channel.
Is it possible, could I limit the maximum scale ratio to 1ms?
You can see attached file "Plotter.JPG", the data type of SpDt_uwPWMAngleErr is unsigned and the maximum I set is 65535, however you can see the value 34.2 in the picture.
What I mean is that no matter how I zoom in, I should always see the interger and no float.
I have another question is that in attached file PCAN_Explorer.jpg, the value of "INV Relay Close Enable" is always 1, but I stop logging, press "Reset" button and start logging, the CAN package does not transmit at this moment.
However, I still see the value of "INV Relay Close Enable" is always 1, but it should be 0 since the CAN package does not transmit at this moment, could you tell me how to fix that?
Marcus
Marcus
- PCAN_Explorer.jpg (241.71 KiB) Viewed 6029 times
- Plotter.JPG (116.85 KiB) Viewed 6029 times
to understand your problem, please send your complete project by email to our support email address. Please put an info about used PCAN-Explorer 5 version and the license number into that email too.
