Mario
Post
by Mario » Sat 2. Mar 2019, 15:10
I am using a native linux.
transmitest works fine:
bnutzer@i7:~/peak-linux-driver-8.7.0/test$ transmitest transmit1.txt -f=/dev/pcanusb32 -b=0x031c -e -n=1
transmitest Version "Release_20150610_n" (www.peak-system.com)
transmitest comes with ABSOLUTELY NO WARRANTY. This is free
software and you are welcome to redistribute it under certain
conditions. For details see attached COPYING file.
transmitest: device node="/dev/pcanusb32"
Extended frames are sent, init with BTR0BTR1=0x031c
Data will be read from "transmit1.txt".
transmitest: driver version = Release_20181116_n
transmit1.txt:
m s 0x00000601 8 40 08 10 00 00 00 00 00
The oscilloscope shows the transmitted message and the response:
- Tx and response - Linux transmitest
- Transmit and Respone Linux transmitest.png (45.73 KiB) Viewed 3684 times
This is the transmitted message:
- Tx message
- Transmit Linux transmitest.png (45.59 KiB) Viewed 3684 times
Seems to be OK.
Best wishes,
Mario
- Support
Post
by M.Maidhof » Mon 4. Mar 2019, 10:32
so all is ok from the driver side. Please check your application again, or use the demo application we provide with the PCANBasic API
Mario
Post
by Mario » Sun 10. Mar 2019, 09:33
thank you for helping me.
Now I can be sure that this is not a driver related problem.
Best wishes,
Mario
