Shortend Ground
Shortend Ground
i received my PLIN-USB today. I created a small adapter from our PCB-Edge-Connector to an female D-Sub Connector. Everything seems fine, but the PLIN View Software says "Bus-Line: Shorted Ground". But there is no obvious short-cut on my adapter? Do i miss somethgin? Our Vbat is about 12 Volt.
Thanks!
O4r
Thanks!
O4r
Re: Shortend Ground
on which pins of your D-Sub did you connect Vbat and GND?
Re: Shortend Ground
like described here: https://www.peak-system.com/PLIN-USB.485.0.html
4 LIN
5 GND
9 Vbat
I don't see the problem ...
Thanks!
O4r
4 LIN
5 GND
9 Vbat
Thanks!
O4r
Re: Shortend Ground
that is ok. Please measure the LIN voltage on the PLIN-USB against GND
Re: Shortend Ground
we have a 5V LIN Voltage and this is what i measure between LIN and GND...
O4r
O4r
Re: Shortend Ground
that is not correct. LIN will only work above 6 Volts (typically 8-18V), please see technical spec in the manual for more details. In your post above you say you use 12Volts?
Re: Shortend Ground
thanks for the answer!
Yes, we have an adopted "LIN" since we are not part of the automotive industry. We have a 4-pin connector with GND, LIN, 5V, 12V, whereas the LIN is also 5V.
So it seems, that i need to make an adapter board (5V<->12V)...
Thank you very much for your help!
O4r
O4r
Re: Shortend Ground
would have been helpfull to tell me those facts in your first post.....
