How to read a UDS Service Response via EVENT
awild
Post by awild » Wed 10. Apr 2019, 12:14
Hi to all,
I trigger a service request via UDSApi.SvcReadDataByIdentifier(). The PID/LEV is 0xFD 0x54.
The reception of the response (33Bytes) workes fine with UDSApi.WaitForService().
However I want the reception to be event driven.
The event fires ok, in the eventhandler I try to pick out the right message by
a) multiple calls of UDSApi.Read() until the result is TPUDSStatus.PUDS_ERROR_NO_MESSAGE
b) checking each received message, for the appropriate type to hold my data
I think TPUDSMessageType.PUDS_MESSAGE_TYPE_INDICATION is an indicator for coming data...
However I get 4 messages with the following content:
Message 1:
MSGTYPE = PUDS_MESSAGE_TYPE_CONFIRM
LEN = 3
DATA = 0x22 0xFD 0x54
Message 2:
MSGTYPE = PUDS_MESSAGE_TYPE_INDICATION
LEN = 33
DATA = 0x62 0xFD 0x54 0xFF 0x4E 0x01 ---> the next bytes ARE NOT INITIALIZED !!!
Message 3:
LEN = 33
DATA = 0x62 0xFD 0x54 0xFF 0x4E 0x01 ---> the data is correct until the end
Message 4:
LEN = 0
DATA = not initialized
So effectivly I get 3! messages with type PUDS_MESSAGE_TYPE_CONFIRM.
What is the best way to filter out the correct message containing the data?
Thanks again for your help
Andy
Re: How to read a UDS Service Response via EVENT
Post by K.Wagner » Wed 10. Apr 2019, 14:59
awild wrote:I think TPUDSMessageType.PUDS_MESSAGE_TYPE_INDICATION is an indicator for coming data...
yes, this is a message indicating that data is pending
awild wrote:However I get 4 messages with the following content:
The Message 1 is the confirmation of your request.
The Message 2 is the beginning of the response; it is normal that not all data bytes are valid since not all the data is retrieved yet.
The Message 3 is the confirmation of the response; the requested data was completely received.
The Message 4 is very strange, especially with a length of 0. We cannot understand this message.
awild wrote: So effectivly I get 3! messages with type PUDS_MESSAGE_TYPE_CONFIRM.
the filtering you mean is actually what the UDS_WaitFor... functions do. If you keep using UDS_Read, you need to check the NETADDRINFO.SA/TA to distinguish request from responses, check that the RESULT field of those is OK (0), that the message type is PUDS_MESSAGE_TYPE_CONFIRM, etc. until you get all your data. Note that you also have to take care about errors like "PUDS_NRC_EXTENDED_TIMING" that can arise when the ECU needs more time to process a request.
Instead of using the UDS_Read, you could use the function UDS_WaitForSingleMessage(). This function waits for a response to a given UDS request. You can still use your even driven approach, but instead of call UDS_Read several times on signal, you call WaitForSingleMessage once.
awild
Post by awild » Wed 10. Apr 2019, 16:11
Hi Keneth,
thank you for the hint, this is indeed much easier and works ok !
However there is something curious in defining the request message for the WaitForSingleMessage() function:
            TPUDSMsg request = new TPUDSMsg();
            request.NETADDRINFO.SA = ClientAdr;
            request.NETADDRINFO.TA = ECUAdr;
            request.NETADDRINFO.TA_TYPE = TPUDSAddressingType.PUDS_ADDRESSING_PHYSICAL;
            request.NETADDRINFO.RA = 0x00;
            request.NETADDRINFO.PROTOCOL = TPUDSProtocol.PUDS_PROTOCOL_ISO_15765_2_29B_NORMAL;
            request.DATA = new byte[4095];
            request.DATA[0] = 0x22;
            request.DATA[1] = 0;
            request.DATA[2] = 0;
            request.LEN = (ushort)request.DATA.Length;
            request.MSGTYPE = TPUDSMessageType.PUDS_MESSAGE_TYPE_REQUEST;
As you can see I set DATA[1]=0 and DATA[2]=0 on purpose in order to check whether WaitForSingleMessage() is able to filter the message correct.
I expected no message reception, because the PID/LEV of the UDS Service is wrong.
But I received the response fine!
Why has DATA[1] and DATA[2] no meaning in terms of selecting the right response?
Thereafter I set DATA[0] = 0x21.
Then there was no reception, as to be expected.
It seems that only the SID is verified to detect the UDS message to receive?
Thank you very much
Andy
Reason: Format applied for better reading
Post by K.Wagner » Wed 10. Apr 2019, 16:25
here an extract of the help that may explain what is happening:
PCAN-UDS API Documentation - Page 117 - wrote: Note: the criteria to identify if a response matches the message request is based only on the network
addressing information and the UDS service identifier: if a same service is requested multiple times with
different parameters (like service ReadDataByIdentifier with different Data IDs), the user will have to
ensure that the extra content matches the original request.
