CAN hangs on RaspberryPi
hardwic
Post by hardwic » Tue 16. Apr 2019, 11:05
I am using a USB-CAN which is supplied by Victron but is a PCAN device on Rpi 3 b+ with 4.14.98-v7+
I compiled the kernel drivers that shipped with OS.
The CAN bus hangs every few hours:
[166262.423367] can: request_module (can-proto-0) failed.
[166361.167539] can: request_module (can-proto-0) failed.
[166756.355582] can: request_module (can-proto-0) failed.
[173719.782304] peak_usb 1-1.1.2:1.0 can0: bus-off
If I bounce the interface, it works again.
I tried 2 different USB adapters and it does the same.
Any ideas what I have wrong?
Reason: Created new thread using this posting. Inserted [code] tags for improved readability.
S.Grosjean
Re: CAN hangs on RaspberryPi
Post by S.Grosjean » Tue 16. Apr 2019, 16:58
Please type:
$ ip -s -d link show can0
Check if the bitrate is ok with the other equipments connected to the bus.
Next, regarding:
Looks like some socket-can module (can-raw ?) is not loaded. Please type:
$ lsmod | grep can
— Stéphane
hardwic
Post by hardwic » Thu 18. Apr 2019, 10:03
4: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10
    link/can  promiscuity 0
    can state ERROR-ACTIVE restart-ms 0
	  bitrate 250000 sample-point 0.875
	  tq 250 prop-seg 6 phase-seg1 7 phase-seg2 2 sjw 1
	  pcan_usb: tseg1 1..16 tseg2 1..8 sjw 1..4 brp 1..64 brp-inc 1
	  clock 8000000
	  0          0          0          3          1          1         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    84823468   10686522 1       144     1       0
    1459391    231552   0       0       0       0
I see a few error warnings etc, not sure if this is bad.
The interface was running at 500kbs but I dropped it to 250kbs.
The interface runs for days at times but then seem to hang. If you restart it with ifdown/ifup, it works again.
For "lsmod | grep can", I get
lsmod | grep can
can_bcm                24576  0
can_raw                20480  3
can                    28672  2 can_raw,can_bcm
can_dev                28672  1 peak_usb
S.Grosjean
Post by S.Grosjean » Thu 18. Apr 2019, 14:07
Please be sure to use a power supply with enough power for both RPi and PCAN-USB. You can check for the yellow lightening bolt on the screen, which will show up when a undervoltage is detected.
— Stéphane
hardwic
Post by hardwic » Thu 18. Apr 2019, 15:45
Aha.. I am running off a bench power supply at 5.1v and the supply can deliver 10A if required.
But the wire to the usb connector on the Pi is a bit this and long and the voltdrop maybe an issue.
let me try shortening that and testing again. Thanks
Reason: Removed full quote of preceding post.
hardwic
Post by hardwic » Fri 19. Apr 2019, 09:52
OK that nailed the problem.Thanks
