ImportError: No module named PCANBasic,on python
MrSingh
Post by MrSingh » Wed 8. May 2019, 02:03
I've installed the PCANBasic api into my ubuntu 18.04 as per the given instructions in the manual.
But while importing the PCANBasic, using
from PCANBasic import *
in my python program, it shows an import error.
Is this related to some directory issue? Should I copy the API files to some location? I have python 2.7 on my system.
Re: ImportError: No module named PCANBasic,on python
Post by M.Maidhof » Wed 8. May 2019, 09:49
please post output of cat /proc/pcan, to see if the chardev driver is installed
MrSingh
Post by MrSingh » Fri 10. May 2019, 14:49
Sorry for late reply. Got caught up in another project.
Here's the output of the cat /proc/pcan
*------------- Release_20190412_n (8.8.0) May  7 2019 23:31:42 --------------
*--------------------- 1 interfaces @ major 236 found -----------------------
32    usb   -NA- ffffffff 030 0x001c 0000000b 00000019 0000452c 0000683e 0x0080
Post by M.Maidhof » Fri 10. May 2019, 16:26
please send us the outputs when you build and install the pcanbasic API package.
Did you run one of our test apps for pcanbasic?
MrSingh
Post by MrSingh » Fri 10. May 2019, 16:49
The outputs for building and installing pcanbasic api :
~/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic$ make clean
make[1]: Entering directory '/home/akash/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic/pcanbasic'
Considering PCANBasic library with FD support (PCAN driver >= 8.0)
rm -f src/*~ src/*.o *~ *.so.* *.so libpcanfd.o
make[1]: Leaving directory '/home/akash/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic/pcanbasic'
make[1]: Entering directory '/home/akash/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic/pcaninfo'
rm -f src/*~ src/*.o ../pcanbasic/src/*~ ../pcanbasic/src/*.o *~ *.so.* *.so pcaninfo.1.0.2 pcaninfo
make[1]: Leaving directory '/home/akash/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic/pcaninfo'
make[1]: Entering directory '/home/akash/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic/examples'
make[2]: Entering directory '/home/akash/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic/examples/python'
rm -f *.pyc
make[2]: Leaving directory '/home/akash/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic/examples/python'
make[2]: Entering directory '/home/akash/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic/examples/c++'
make[2]: Leaving directory '/home/akash/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic/examples/c++'
make[1]: Leaving directory '/home/akash/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic/examples'
*** Making PCANBasic library with FD support (PCAN driver >= 8.0)
*** target=libpcanbasic
*** version=4.3.1
*** PCAN_ROOT=src/pcan
*** gcc version=7
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -Isrc/pcan/driver -Isrc/pcan/lib  -c src/libpcanbasic.c -o src/libpcanbasic.o
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -Isrc/pcan/driver -Isrc/pcan/lib  -c src/pcaninfo.c -o src/pcaninfo.o
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -Isrc/pcan/driver -Isrc/pcan/lib  -c src/pcanlog.c -o src/pcanlog.o
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -Isrc/pcan/driver -Isrc/pcan/lib  -c src/pcbcore.c -o src/pcbcore.o
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -Isrc/pcan/driver -Isrc/pcan/lib  -c src/pcblog.c -o src/pcblog.o
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -Isrc/pcan/driver -Isrc/pcan/lib  -c src/pcbtrace.c -o src/pcbtrace.o
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -Isrc/pcan/driver -Isrc/pcan/lib  -c src/pcan/lib/src/libpcanfd.c -o src/libpcanfd.o
gcc -shared -Wl,-soname,libpcanbasic.so -o libpcanbasic.so.4.3.1 src/libpcanbasic.o src/pcaninfo.o src/pcanlog.o src/pcbcore.o src/pcblog.o src/pcbtrace.o src/libpcanfd.o -lm
ln -sf libpcanbasic.so.4.3.1 libpcanbasic.so
*** Making PCANINFO
*** target=pcaninfo
*** version=1.0.2
*** PCAN_ROOT=../pcanbasic/src/pcan
*** gcc version=7
gcc src/main.c ../pcanbasic/src/pcanlog.c ../pcanbasic/src/pcblog.c ../pcanbasic/src/pcbtrace.c ../pcanbasic/src/pcbcore.c ../pcanbasic/src/pcaninfo.c ../pcanbasic/src/pcan/lib/src/libpcanfd.c -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I../pcanbasic/src -I../pcanbasic/src/pcan/driver -I../pcanbasic/src/pcan/lib  -lm  -o pcaninfo.1.0.2
ln -sf pcaninfo.1.0.2 pcaninfo
make[2]: Nothing to be done for 'all'.
*** Making PCANBasic C++ examples
*** g++ version=7
*** PCANBASIC_ROOT=../../pcanbasic
g++ -I../../pcanbasic -I../../pcanbasic/src/pcan/driver -DNO_RT src/pcanwrite.cpp -L../../pcanbasic -Wl,-rpath ../../pcanbasic -lpcanbasic -o pcanwrite
g++ -I../../pcanbasic -I../../pcanbasic/src/pcan/driver -DNO_RT src/pcanread.cpp -L../../pcanbasic -Wl,-rpath ../../pcanbasic -lpcanbasic -o pcanread
g++ -I../../pcanbasic -I../../pcanbasic/src/pcan/driver -DNO_RT src/pcaneventread.cpp -L../../pcanbasic -Wl,-rpath ../../pcanbasic -lpcanbasic -o pcaneventread
g++ -I../../pcanbasic -I../../pcanbasic/src/pcan/driver -DNO_RT src/pcaneventwrite.cpp -L../../pcanbasic -Wl,-rpath ../../pcanbasic -lpcanbasic -o pcaneventwrite
~/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic$ sudo make install
[sudo] password for akash:
cp libpcanbasic.so.4.3.1 /usr/lib/libpcanbasic.so.4.3.1
ln -sf /usr/lib/libpcanbasic.so.4.3.1 /usr/lib/libpcanbasic.so.4
ln -sf /usr/lib/libpcanbasic.so.4.3.1 /usr/lib/libpcanbasic.so.0
/sbin/ldconfig
cp pcaninfo.1.0.2 /usr/local/bin/pcaninfo
make[2]: Nothing to be done for 'install'.
I tried running the python example file, PCANBasic.py, but it gives me the import library error, for which I started this thread.
Akash
MrSingh
Post by MrSingh » Mon 13. May 2019, 02:26
I tried running the receivetest, and got the following output.
$ /usr/local/bin/receivetest -f=/dev/pcan32 -e
receivetest Version "Release_20150611_n"  (www.peak-system.com)
receivetest comes with ABSOLUTELY NO WARRANTY.     This is free
receivetest: device node="/dev/pcan32"
             Extended frames are accepted, init with 500 kbit/sec.
receivetest: driver version = Release_20190412_n
2928728910.987 receivetest: x - 0x00000001 4 00 00 00 00
receivetest: pending CAN status 0x0020 read.
^Creceivetest: type            = usb
             Serial Number   = 0xffffffff
             Device Number   = 30
             count of reads  = 1
             count of writes = 0
             count of errors = 0
             count of irqs   = 26
             last CAN status = 0x0000
             last error      = 0
             open paths      = 1
receivetest: finished (0): 1 message(s) received
Does this mean driver has not been correctly installed?
F.Vergnaud
Post by F.Vergnaud » Mon 13. May 2019, 11:09
Can you copy the result of the following commands.
# moves to the PCANBasic python example directory
cd ~/PCAN/PCAN-Basic_Linux-4.3.1/
cd libpcanbasic/examples/python/
# fetches the name of the PCANBasic library that is loaded by python
grep -e '__m_dllBasic = cdll.LoadLibrary(".*")' PCANBasic.py
# asserts the above library exists in the filesystem
ls -al /usr/lib/`grep -e '__m_dllBasic = cdll.LoadLibrary(".*")' PCANBasic.py | sed 's:^.*"\(.*\)".*$:\1:'`
You should expect a valid symlink for the last command:
lrwxrwxrwx 1 root root 26 13 mai   10:12 /usr/lib/libpcanbasic.so -> /usr/lib/libpcanbasic.so.4
Finally can you copy the output of the PCANBasic import from a python console:
python2.7
Thank you.
Fabrice
MrSingh
Post by MrSingh » Mon 13. May 2019, 16:08
OK. The import works in the terminal now, although I did try before as well.
But Still does not work in PyCharm.
This is the output in Pycharm
The result of the first set of commands is same as expected, but I will put it here for clarity.
~/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic/examples/python$ grep -e '__m_dllBasic = cdll.LoadLibrary(".*")' PCANBasic.py
            self.__m_dllBasic = cdll.LoadLibrary("libpcanbasic.so")
~/PCAN/PCAN-Basic_Linux-4.3.1/libpcanbasic/examples/python$ ls -al /usr/lib/`grep -e '__m_dllBasic = cdll.LoadLibrary(".*")' PCANBasic.py | sed 's:^.*"\(.*\)".*$:\1:'`
lrwxrwxrwx 1 root root 26 maj 13 02:35 /usr/lib/libpcanbasic.so -> /usr/lib/libpcanbasic.so.4
MrSingh
Post by MrSingh » Mon 13. May 2019, 16:10
MrSingh wrote:I tried running the receivetest, and got the following output.
             Device Number   = 30
             count of reads  = 1
             count of writes = 0
             count of errors = 0
             count of irqs   = 26
             last error      = 0
             open paths      = 1
But this behavior has still not changed.!!
F.Vergnaud
Post by F.Vergnaud » Mon 13. May 2019, 16:24
Sorry I didn't respond to your receivetest concern because it is working fine ;)
This tool infinetely waits for CAN messages, you are receiving a single message which is a status frame stating that the device is up and active.
You then hit Ctrl-C (^C) which closed the application.
Back to python, your issue lies within the configuration of PyCharm IDE: you have to specify where to find the file PCANBasic.py.
Fabrice
