I have PCAN-USB FD device. I try run simple example from documentation.
from PCANBasic import *
# Defines a FD Bit rate string with nominal and data Bit rate set to 1 MB
bitrate = "f_clock_mhz=24, nom_brp=1, nom_tseg1=17, nom_tseg2=6, nom_sjw=1, data_brp=1, data_tseg1=16, data_tseg2=7, data_sjw=1"
# The FD capable Channel (PCAN-USB Pro FD) is initialized
objPCAN = PCANBasic()
result = objPCAN.InitializeFD(PCAN_USBBUS1, bitrate)
if result != PCAN_ERROR_OK:
print result[1]
else:
print "PCAN-USB Pro FD (Ch-1) was initialized"
# All initialized channels are released
objPCAN.Uninitialize(PCAN_NONEBUS)
A PCAN Channel has not been initialized yet or the initialization process has failed
PCAN driver version: 8.8.0
* pcanusbfd32: (/sys/class/pcan/pcanusbfd32)
- file: /dev/pcan32
- dev: "240:32"
- dev_name: "/dev/pcan32"
- minor: 32
- base: 0
- irq: 0
- adapter_name: "PCAN-USB FD"
- adapter_number: 0
- adapter_version: "3.2.0"
- type: "usbfd"
- hwtype: 18
- devid: 0x00
- ctrlr_number: 0
- mass_storage_mode: 0
- clock: 8 MHz
- nom_bitrate: 1 MBit/s
- btr0btr1: 0x14
- data_bitrate: 2 MBit/s
- init_flags: 0
- clk_drift: 131072
- ts_fixed: 0
- nom_brp: 1
- nom_sample_point: 7.50%
- nom_sjw: 1
- nom_tseg1: 59
- nom_tseg2: 20
- nom_tq: 12
- data_brp: 1
- data_sample_point: 7.50%
- data_sjw: 1
- data_tseg1: 29
- data_tseg2: 10
- data_tq: 12
- bus_state: OK (1)
- bus_load: 0%
- rx_error_counter: 0
- tx_error_counter: 0
- tx_fifo_ratio: 0%
- irqs: 0
- status: 0
- errors: 0
- read: 0
- write: 0
- TPCANHandle: "PCAN_USBBUS1" (0x051)
Help me.
