It looks like that module is working in normal operation mode (pcan_pcan.png)
Also tried to reload configuration with changed can speed for one channel to check if I am reloading confiugration correctly. CAN speed was changed but I am still in normal operation mode and not listen operation mode
Listen mode
Re: Listen mode
- pcan_pcan.png (28.91 KiB) Viewed 6298 times
Re: Listen mode
Hm..curios
please post a screenshot with the used version and PPCAN version information Furthermore press the right mouse button and read the current configuration from the module, save the config and post it also. regards
Re: Listen mode
In attachment
- read_from_device_version.png (10.87 KiB) Viewed 6292 times
- read_from_device_0.ppproj
- (17.27 KiB) Downloaded 624 times
Re: Listen mode
Hi Lukas,
we are able to reproduce your problem, it´s an issue of the used transceiver module in combination with the used firmware which could happen under some circumstances
Please contact us per email and we send you a new firmware + necessary tools/instructions for the update process.
