Page 3 of 16
Re: PEAK-Linux Driver on Raspberry Pi
Posted: Tue 25. Jun 2013, 15:22
looks ok. Please send the full output of your make process. Check also dmesg for relevant outputs. Please update your PI to the latest version: sudo apt-get update, sudo apt-get upgrade.
Posted: Wed 26. Jun 2013, 13:17
by mohamed mahmoud
I updated PI to the latest version, and the problem still exists. Here's the build output:
make[1]: Entering directory `/root/Downloads/peak-linux-driver-7.8/driver'
make[1]: *** No rule to make target `depend'.  Stop.
make[1]: Leaving directory `/root/Downloads/peak-linux-driver-7.8/driver'
*** Host machine kernel version=3.6.11+
*** Driver kernel version=3.6.11
*** Path to kernel sources=/lib/modules/3.6.11+/build
*** use KBUILD=yes
make -C /lib/modules/3.6.11+/build SUBDIRS=/root/Downloads/peak-linux-driver-7.8/driver        EXTRA_CFLAGS="-I/root/Downloads/peak-linux-driver-7.8/driver        -DNO_DEBUG -DMODVERSIONS -DNO -DUSB_SUPPORT -DNO -DNO_PCIEC_SUPPORT -DNO -DNO -DNO -DNO -DNO_RT " V=0 modules
make[2]: Entering directory `/usr/src/linux-headers-3.6.11+'
  WARNING: Symbol version dump /usr/src/linux-headers-3.6.11+/Module.symvers
           is missing; modules will have no dependencies and modversions.
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_main.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_fops.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_fifo.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_filter.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_parse.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_sja1000.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_common.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_usb_core.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_usb.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_usbpro.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_timing.o
  LD [M]  /root/Downloads/peak-linux-driver-7.8/driver/pcan.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /root/Downloads/peak-linux-driver-7.8/driver/pcan.mod.o
  LD [M]  /root/Downloads/peak-linux-driver-7.8/driver/pcan.ko
make[2]: Leaving directory `/usr/src/linux-headers-3.6.11+'
make[1]: Entering directory `/root/Downloads/peak-linux-driver-7.8/lib'
cc src/libpcan.c -fPIC -shared -O2 -Wall -Wl,-soname,libpcan.so.0 -lc -I. -I../driver -DNO_RT -o libpcan.so.0.6
make[1]: Leaving directory `/root/Downloads/peak-linux-driver-7.8/lib'
make[1]: Entering directory `/root/Downloads/peak-linux-driver-7.8/test'
cc src/receivetest.c src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o receivetest   -lpcan -DNO_RT
cc src/transmitest.cpp src/common.c src/parser.cpp -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o transmitest   -lpcan -lstdc++ -DNO_RT
cc src/bitratetest.c src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o bitratetest   -lpcan -DNO_RT
cc src/filtertest.cpp src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o filtertest   -lpcan -lstdc++ -DNO_RT
cc src/pcan-settings.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o pcan-settings   -lpopt -g
make[1]: Leaving directory `/root/Downloads/peak-linux-driver-7.8/test'
Posted: Thu 27. Jun 2013, 11:21
so here is the output from my Pi:
mm@raspberrypi ~/peak-linux-driver-7.8/driver $ uname -r
3.6.11+
mm@raspberrypi ~/peak-linux-driver-7.8/driver $ make clean
rm -f src/*o src/*~ src/.*cmd *o *ko *~ .*cmd  pcan.mod.c
mm@raspberrypi ~/peak-linux-driver-7.8/driver $ make NET=NO PCI=NO PCC=NO ISA=NO DNG=NO PAR=NO
*** use KBUILD=yes
make -C /lib/modules/3.6.11+/build SUBDIRS=/home/mm/peak-linux-driver-7.8/driver        EXTRA_CFLAGS="-I/home/mm/peak-linux-driver-7.8/driver        -DNO_DEBUG -DMODVERSIONS -DNO -DUSB_SUPPORT -DNO -DNO_PCIEC_SUPPORT -DNO -DNO -DNO -DNO -DNO_RT " V=0 modules
make[1]: Entering directory `/usr/src/linux-headers-3.6.11+'
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_main.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_fops.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_fifo.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_filter.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_parse.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_sja1000.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_common.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_usb_core.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_usb.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_usbpro.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_timing.o
  LD [M]  /home/mm/peak-linux-driver-7.8/driver/pcan.o
  MODPOST 1 modules
  CC      /home/mm/peak-linux-driver-7.8/driver/pcan.mod.o
  LD [M]  /home/mm/peak-linux-driver-7.8/driver/pcan.ko
make[1]: Leaving directory `/usr/src/linux-headers-3.6.11+'
mm@raspberrypi ~/peak-linux-driver-7.8/driver $ sudo insmod pcan.ko
mm@raspberrypi ~/peak-linux-driver-7.8/driver $ cat /proc/pcan
*------------- Release_20130131_n (7.8.0) Jun 27 2013 11:07:58 --------------
*------------------------------- [mod] [usb] --------------------------------
*--------------------- 1 interfaces @ major 248 found -----------------------
32    usb -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
please do the same steps on your system. Please do those steps in the \driver directory only.
Posted: Thu 27. Jun 2013, 12:14
by mohamed mahmoud
I solved the problem. the file Module.symvers was messing in the kernel-headers. i downloaded it from github then i placed it in /usr/src/linux-headers-3.6.11+, then i re-built the driver and it worked this time. now , i can load the module.
Here's the link where i downloaded Module.symvers:
https://github.com/raspberrypi/firmware ... le.symvers
Posted: Mon 15. Jul 2013, 11:34
by emilio.munoz
Finally I could install the driver. The problem in my case was that at the utsrelease.h located in the folder of the linux-headers was written "3.6.11", so I have to add the "+"
Anyway, now I am having a different problem, because I compiled the kernel and now when I try to install the driver it appers the following error: "can't find /include/linux/version.h"
The thing is that now my kernel version is different, because when I write uname -r I get "3.6.11-cutdown+". I guess this is the problem, but I don't know how to solve it.
thanks for your attention.
Emilio
Posted: Tue 16. Jul 2013, 10:58
Have you checked that you have a symbolic link to your header file directory?
See PDF Docu, page 14, section 5.2.1:
Up from kernel version 2.6.x the completely configured
kernel sources for your target system have to be installed. If
it is a standard installation the sources are located under
“/usr/src/linux“ in which this normally is a link e.g. to
“/usr/src/linux-2.6.6“. For every kernel smaller or equal than
2.4.x only the “kernel-headers“ have to be installed. (It's not
wrong to install the complete sources of the target system.)
The kernel-headers are installed if the invocation of “cat
/lib/modules/'uname -r'/build/include/linux/modversions.h“
is ending without an error. (“'uname -r'“ is a placeholder for
the result of the invocation “uname -r“.)
Posted: Wed 17. Jul 2013, 16:42
by emilio.munoz
Yes....that was the problem!! Thanks! Now it works!.
The only thing is that when I try to install a NETDEV driver utility and I compile your driver with
make NET=NETDEV_SUPPORT PCI=NO PAR=NO ISA=NO PCC=NO DNG=NO
what I get with cat /proc/pcan command is:
│*n -type- ndev --base-- irq --btr- --read-- --write- --irqs-- -errors- status
│32 usb -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
The ndev column should be can0 instead of -NA-. I know that the SocketCAN option is not enabled in the kernel config of the Raspberry PI, but I tried to compile the kernel following some instructions: (http://elinux.org/RPi_CANBus) but it is still not working with the can0 at ndev.
I don't know what I can be doing wrong
Posted: Wed 17. Jul 2013, 17:15
You have compiled the CharDev Driver
have you removed the CharDev driver before you try to install the NetDev?
Posted: Thu 29. Aug 2013, 12:59
by ckeydel
Hi Michael,
I am trying the same thing right now but can't get the kernel module to load. I have a brand new RPi, the latest standard wheezy from the Raspberry Pi foundation, completely updated system and I followed the instructions to the letter. Here is the output of my build:
pi@raspberrypi ~/install/peak-linux-driver-7.8/driver $ uname -r
3.6.11+
pi@raspberrypi ~/install/peak-linux-driver-7.8/driver $ make clean
pi@raspberrypi ~/install/peak-linux-driver-7.8/driver $ make NET=NO PCI=NO PCC=NO ISA=NO DNG=NO PAR=NO
*** use KBUILD=yes
make -C /lib/modules/3.6.11+/build SUBDIRS=/home/pi/install/peak-linux-driver-7.8/driver        EXTRA_CFLAGS="-I/home/pi/install/peak-linux-driver-7.8/driver        -DNO_DEBUG -DMODVERSIONS -DNO -DUSB_SUPPORT -DNO -DNO_PCIEC_SUPPORT -DNO -DNO -DNO -DNO -DNO_RT " V=0 modules
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_main.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_fops.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_fifo.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_filter.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_parse.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_sja1000.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_common.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_usb_core.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_usb.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_usbpro.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_timing.o
  LD [M]  /home/pi/install/peak-linux-driver-7.8/driver/pcan.o
  MODPOST 1 modules
  CC      /home/pi/install/peak-linux-driver-7.8/driver/pcan.mod.o
  LD [M]  /home/pi/install/peak-linux-driver-7.8/driver/pcan.ko
pi@raspberrypi ~/install/peak-linux-driver-7.8/driver $ sudo insmod pcan.ko
Error: could not insert module pcan.ko: Invalid module format
It looks exactly like yours, except I can't load the module. Any ideas?
Cheers,
Chris
Posted: Fri 30. Aug 2013, 08:52
Hi Chris,
i do not see any differnt between the way you did it and how Michael show how to do it.
Have you any news? Solution?
