felgo
Post by felgo » Wed 17. Feb 2016, 18:19
Hi Michael,
I'm working with RPi2 and kernel 4.1.13. (current Raspbian), I can modprobe the can modules but ifconfig -a doesn't show any can device. Booting with the 3.18 kernel everthing works fine. Do I have to recompile the 4.1.13 kernel for activating socketcan?
BTW: If I try to compile the peak-linux-driver like you've written above, the pcan module could not be found
Thanks for your support!
Felix
Post by M.Maidhof » Thu 18. Feb 2016, 14:02
please follow the follwing post, to check if SocketCAN Config is enabled in your kernel.
http://www.peak-system.com/forum/viewto ... t=80#p4706
Yes, worst case will be to recompile the kernel with that option
To get behind the problem with your peak-linux-driver, we need the output of your build process.
felgo
Post by felgo » Thu 18. Feb 2016, 14:18
Hi Michael,
like Rob discribed above, this file is also not present in my system.
pi@raspberrypi:~ $ uname -r
4.1.13-v7+
pi@raspberrypi:~ $ ls /boot/config*
/boot/config-3.18.0-trunk-rpi  /boot/config-3.18.0-trunk-rpi2  /boot/config.txt
The output of my driver installation looks like this:
pi@raspberrypi:~/peak-linux-driver-7.15.2 $ make NET=NO PCI=NO PAR=NO ISA=NO PCC=NO DNG=NO
make[1]: Entering directory '/home/pi/peak-linux-driver-7.15.2/driver'
Makefile:102: *** "Can't find /include/linux/version.h".  Schluss.
make[1]: Leaving directory '/home/pi/peak-linux-driver-7.15.2/driver'
make[1]: Entering directory '/home/pi/peak-linux-driver-7.15.2/lib'
cc src/libpcan.c -DNO_RT -I. -I../driver -fPIC -shared -O2 -Wall  -Wl,-soname,libpcan.so.0 -lc  -o libpcan.so.0.6
make[1]: Leaving directory '/home/pi/peak-linux-driver-7.15.2/lib'
make[1]: Entering directory '/home/pi/peak-linux-driver-7.15.2/test'
cc -DNO_RT -g -I. -I../lib -I../driver  src/receivetest.c src/common.c  -lpcan -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o receivetest
cc -DNO_RT -g -I. -I../lib -I../driver  src/transmitest.cpp src/common.c src/parser.cpp  -lpcan -L../lib -L/lib -L/usr/lib -L/usr/local/lib -lstdc++ -o transmitest
cc -DNO_RT -g -I. -I../lib -I../driver  src/bitratetest.c src/common.c  -lpcan -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o bitratetest
cc -DNO_RT -g -I. -I../lib -I../driver  src/filtertest.cpp src/common.c  -lpcan -L../lib -L/lib -L/usr/lib -L/usr/local/lib -lstdc++ -o filtertest
cc -DNO_RT -g -I. -I../lib -I../driver  src/pcan-settings.c  -lpcan -L../lib -L/lib -L/usr/lib -L/usr/local/lib -lpopt -g -o pcan-settings
make[1]: Leaving directory '/home/pi/peak-linux-driver-7.15.2/test'
pi@raspberrypi:~/peak-linux-driver-7.15.2 $ sudo make install
mkdir -p /usr/lib
cp libpcan.so.0.6 /usr/lib/libpcan.so.0.6
ln -sf /usr/lib/libpcan.so.0.6 /usr/lib/libpcan.so.0
ln -sf /usr/lib/libpcan.so.0 /usr/lib/libpcan.so
mkdir -p /usr/include
cp libpcan.h ../driver/pcan.h /usr/include
chmod 644 /usr/include/libpcan.h /usr/include/pcan.h
/sbin/ldconfig
cp receivetest transmitest bitratetest filtertest pcan-settings /usr/local/bin
pi@raspberrypi:~/peak-linux-driver-7.15.2 $ sudo modprobe pcan
modprobe: FATAL: Module pcan not found.
I have installed all packages that may be necessary (linux-headers, build-essential etc.)
I am not sure, what I am doing wrong or if this is a fundamental problem with 4.1.x kernel.
Post by M.Maidhof » Thu 18. Feb 2016, 15:40
the missing version.h means that you haven´t installed the kernel headers. Without headers it is not possible to build a kernel module. It is a known problem, that some of the PI images don´t offer the suitable kernel headers. Please see some older posts in that thread regarding that issue. A good solution was always to install an rpi kernel, for which the needed headerfiles and kernel source were available.
Remember: when you have a kernel image without availabe kernel source, it will also not be possible to configure and recompile the kernel. So this will always be a bad choice under linux, when you want to build own kernel modules.
felgo
Post by felgo » Thu 18. Feb 2016, 18:16
Thanks Michael,
you are right, I installed the linux-headers for the wrong kernel version ;-)
And 4.1.13-v7+ is shipped without kernel-headers.
I now got the driver installed using precompiled heades from here:
https://www.niksula.hut.fi/~mhiienka/Rp ... aders-rpi/
For the installation I used the NET=NETDEV_SUPPORT option and now modprobe pcan an cat /dev/pcan* are working. But now I am faced with the next issue. I can't use socketcan. can0 could not be found. Ifconfig -a doesn't show me any CAN device. I modprobed all the can modules:
 pi@raspberrypi:~ $ lsmod | grep can
can_bcm                13041  0
can_raw                 7204  0
can_dev                 9607  0
can                    27535  2 can_bcm,can_raw
pcan                   56655  0
Do you have an idea how to get soketcan running?
Felix
Post by M.Maidhof » Fri 19. Feb 2016, 09:30
please post the output of cat /proc/pcan
felgo
Post by felgo » Fri 19. Feb 2016, 15:25
after reinstalling everything, SocketCAN seems to work now.
For everyone with the same probs, installing PCAN with netdev support on the PRi, I used this manual:
http://qiita.com/mt08/items/6d50193df85 ... B%E3%83%89
(just replace NET=NO with NET=NETDEV_SUPPORT in the make call)
For me, this is running with kernel versions 4.1.17-v7+ and 4.1.13-v7+.
Thanks Micheal and regards
Post by M.Maidhof » Tue 28. Jun 2016, 11:39
to compile our peak-linux-driver on a RPI you always need the kernel headers which fits to your installed kernel version. When you can´t find the exact kernel headers with apt-get, you could use the following tool, which works perfect on my RPI3 with raspbian jessie and kernel 4.4.13-v7+:
# get & install kernel headers
git clone https://github.com/notro/rpi-source
cd rpi-source
chmod +x rpi-source
sudo apt-get install bc
./rpi-source
# get & install PEAK drivers
wget http://www.peak-system.com/fileadmin/me ... 8.1.tar.gz
tar -xzf peak-linux-driver-8.1.tar.gz
cd peak-linux-driver-8.1
# install required dependencies (peak-driver)
sudo apt-get install libpopt-dev
# build chardev driver
make PCI=NO PCIEC=NO PCC=NO DNG=NO PAR=NO ISA=NO
sudo make install
sudo modprobe pcan
# check PEAK devices
cat /proc/pcan
done!
roitherm
Post by roitherm » Wed 1. Feb 2017, 16:01
Hello!
I tried installing our PAK can adapter on a raspberry pi 2.
most things I found failed, until I read the lines above - I followed that, and now "cat /proc/pcan" gives me:
*------------- Release_20170110_n (8.3.0) Feb  1 2017 14:07:03 --------------
*--------------------- 1 interfaces @ major 243 found -----------------------
32    usb   -NA- ffffffff 000 0x001c 00000000 00000000 00000000 00000000 0x0000
However I sill don't have a "can0" or similar to talk to. What am I doing wrong?
ps: I need to talk can-open on that interface. preferrably using node-red. does anyone have an idea how I can accomplish this?
Post by M.Maidhof » Wed 1. Feb 2017, 16:19
you have build the driver 8.3 for chardev (which is the default build since 8.x). If you like to build the driver for Netdev, simply build it again with make NET=NETDEV_SUPPORT.
See driver manual for more details.
