Mathematical operation in vb scripts
PMJ
Post by PMJ » Thu 17. Jul 2014, 09:18
Hello.
Is it possible in VBS macro modulo operation, hex to dec and dec to hex????
K.Wolf
Re: Mathematical operation in vb scripts
Post by K.Wolf » Thu 17. Jul 2014, 16:06
Yes, all that is possible.
Modulo:
Dim A
A = 16 Mod 5
MsgBox A
The result is 1.
hex -> dec conversion:
Dim d
d = 255
MsgBox Hex(d)
The result is FF.
dec -> hex conversion:
Dim h
h = "&HFF"
MsgBox CInt(h)
h = &HFF
MsgBox h
The result is in both cases 255.
PMJ
Post by PMJ » Fri 18. Jul 2014, 09:13
thanks it's works.
I have second problem. I need write to ex. x=2 200 000 000. In this moment i have comunicate x overflow.
In my opinion the best solution is a change x to double but i don't how.
K.Wolf
Post by K.Wolf » Fri 18. Jul 2014, 11:58
You can assign large values to VBS variables without errors and calculate something with it, the VBS scripting engine then internally works with floating point numbers (double). But many functions in VBS are limited to signed 32-bit integer values, the highest value of which is 2147483647.
