MicroMod Configuration - Hardware Connection
jordank
Post by jordank » Thu 17. Jul 2014, 15:54
I'm using the PCAN MicroMod Configuration tool and attempting to connect to the board via a PCAN USB. When I go to select the PCAN USB under Configuration, Options, Net Select there is only a single Internal Net option. I would like to have the Hardware tab in place of the Net Select but the Net Select option is automatically appearing. I do not have the PCAN Net Configuration software installed with the only other software I have on the unit being PCAN USB view. I simply need to change the baud rate of the bus to 500k to reprogram the unit once to 1Mbit and then I'll be fine with 1Mbit. Thanks!
Re: MicroMod Configuration - Hardware Connection
Post by M.Maidhof » Thu 17. Jul 2014, 16:44
when you only see the net select option in PCAN-MicroMod Config tool, the setup of that software detected a canapi2 interface on your system. To restore this to the hardware select option, please rename the PCAN_System.dll to PCAN_System.dll.old under c:\Program Files\PCAN-MicroMod 2\ and restart PCAN-MicroModConfig again
jordank
Post by jordank » Thu 17. Jul 2014, 17:53
Hi Michael,
I attempted that and the Hardware tab did not appear.
Post by M.Maidhof » Fri 18. Jul 2014, 11:30
please search your whole system for that pcan_system.dll, on some systems you will find that dll in the Windows\system32 or Windows\syswow64 directory too.
jordank
Post by jordank » Mon 21. Jul 2014, 19:22
I was able to find another PCAN_System under the syswow64 directory and am now able to reach the hardware tab. Thank you for your assistance!
